Gateway e4500d my pc turn on automatically when i plug the power code but it does not boot or display nothing on the screen or no beeps with memory or without memory what could be the problem
  • nathan Agboka
    nathan Agboka Oct 21, 2013
    they is a light on the motherboard and the funs are running i have done a test on the processor and it took 20 seconds before i feel little heat on the processor could it be that the processor is bad?
    Master:
  • 359 Answers
It may be your motherboard that is failing. Your LEDs and fans turn on but do you see any lights on your motherboard, or do any of the fans on the CPU start running?
Posted on Oct 20, 2013
  • nathan Agboka
    the light on the motherboard is on and the funs runs normal and i run a test on the processor and it took me 20 seconds to feel a little heat on the processor could it be that the processor is bad?
SOURCE: ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Posted on Nov 20, 2008
  • 37 Answers
SOURCE: Gateway Solo 1150 error code
Remove the battery. Start the computer on AC power only. Computer should start up OK. This is a sign that the battery has had it. A new battery might be needed.
John.
Posted on Jan 03, 2009
  • 90 Answers
SOURCE: won't boot..getting 2 short beep codes..have tried memory that i know is good.
Its the problem with the memory only. the memory u get from dell will noit suite ur pc. try changing the same type and speed memory
Posted on Apr 20, 2009
  • 5 Answers
SOURCE: MSI NVIDIA MCP73PV Motherboard will not boot
you fried your motherboard, buy a new one or a new computer, it's up to you.
Posted on Sep 17, 2009
Testimonial: "Thank you for you time"
Geodavis
  • 45 Answers
SOURCE: compaq evo d51s beeps on boot
Try replacing the RAM (Random Access Memory) Stick
Thanks
Posted on Oct 25, 2009
Samsung r519 not booting, black screen but working
Plug in an external monitor. If you get display then either the screen is bad or the inverter.
If you get nothing, try removing the memory and booting the computer. If you get BIOS and it starts beeping one or more of the memory modules is bad. If you still get nothing then you will want to replace the motherboard.
Dec 15, 2012 | Samsung R519-53S Notebook
Black screen won't boot
From the description it is the motherboard that has major issues, sub out the ram memory one at a time and test each, If there is no change! the motherboard unfortuneately is the problem, only option is to replace board or laptop.
Apr 22, 2012 | Gateway P7908u FX Notebook
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
I have a Gateway MX 3228 laptop that does nothing. I can hear a slight sound from the area of the hard drive when I turn it on. The battery is supplying some power as the button light illuminates when the...
If you get no display at all, it could be failed memory.
Find and open the memory slot, remove and reinstall whatever memory module you find and retry it.
Many systems I've seen will do absolutely nothing if memory is faulty; they do not give any POST beeps, displays or start to read from the hard drive.
The hard drive will spin up when power is applied but will not start their own self-test or look for the boot sector if bad memory is in play.
Good luck-
Oct 24, 2009 | Gateway MX3228 Notebook
Turns on, no bios no screen, just beep.
Now the question is, when the computer first starts up and you hear the beep, that is where it will tell you what your problem is depending on the beep you get.
One Long and one Short Beep = Motherboard issue
One Long and Two Short Beeps = Video (Mono/CGA Display Circuitry) issue
One Long and Three Short Beeps = Video (EGA) Display Circuitry
Three Long Beeps = Keyboard error
One Beep, Blank or Incorrect Display = Video Display Circuitry
If it is the last one, then try doing the following.
1. Disconnect external devices = Unplug everything from the back of the computer and then restart it. If it starts up, then it is one of the peripherals that is plugged in. You will then need to turn off the computer and gradually plug each one in and turn the PC back on to see if the peripheral is the problem. If that isn't the problem, the proceed to #2.
2. Cable check = With the computer shut down, make sure all the cables within the PC are attached properly. Once you finish doing that, turn on the PC and that isn't the cause, continue on...
3. Disconnect all expansion cards = Sometimes another expansion card can become loose and cause various amounts of issues. Remove each expansion card (clean them if necessary of dust) and replace them. Turn on your PC. If it doesn't start move to the next step.
4. Disconnect all drives = disconnect the data cables from the CD-ROM, hard drive, and floppy drive from the motherboard (make sure to mark them so you remember where they plugged into). This will either remedy the situation or you will see an error when you reconnect each device one at a time to determine which device/cable is causing the issue.
5. Remove the RAM = Loose or bad RAM can cause PC's to not boot or boot incorrectly. Remove each stick and replace them one by one alone in each memory slot. If the PC boots up in each slot, then your golden, but if a slot is defective, then your motherboard is damaged in that slot. You can still use the other slots as long as you use the defective one. If a stick of RAM doesn't allow your computer to boot up, its quite possible that stick of RAM is defective and will need to be replaced. But make sure you try out all the other options before throwing away a stick merely because the PC doesn't boot. A faulty stick can be the problem, but if the problem lies elsewhere, you may be throwing away a good stick of memory thinking it may be bad.
6. Disconnect and reconnect the CPU = Most CPU's are easy to remove, but if you aren't familiar with it. Read your manual on how to remove the CPU. Once you remove it and re-seat the CPU, reboot your PC.
7. If after you have tried all the previous steps and your PC still doesn't boot, then it is most likely that your motherboard, CPU, RAM, or power supply is defective and must be replaced. If you are unfamiliar with fixing the problem (or have never built your own PC) you can opt to have someone repair it or you can start with the cheapest option of purchasing a single stick of new memory and see if the memory was indeed the original problem. If the PC still does not boot with new memory, then it is most likely your motherboard, CPU, or power supply that is dire straights.
Aug 28, 2009 | Gateway GT5028 PC Desktop
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
Jun 13, 2009 | Gateway 506GR PC Desktop
Older Gateway e3200 powers on but the screen does not turn on
.. Your board may need flashing..
Remove the side panel.
unplug the system
remove the battery from the main board, pry it loose,
remove memory (rams)
press the power button and hold it for 10 sec
replace battery and rams, plug in and turn on!
if you hear nultiple beeps the memory is damaged and needs replacing
if you hear beeps and slow intervals or none at all processor is damaged
other than that it should boot.
ps. Enter settings or bios and load defaults or optimal then save and exit. ... > after flashing.
Apr 03, 2009 | Computers & Internet
Laptop keeps beeping and not turning on
I think you may mean the Hard Disk light not floppy, although, if you have a floppy disc drive, check there's no floppy disc in it as it will stop the boot up. But if it's not the floppy, and the hard disc drive light stays on, possibly the hard drive is faulty, maybe damaged sectors. The other maybe is a possible memory fault, although the beep codes can only be identified if you know the motherboard make. Your rating are important.
Nov 22, 2006 | Gateway M350 Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
