Print head calibration confidence level 0 - Office Equipment & Supplies
5 Suggested Answers
proton77
  • 1183 Answers
SOURCE: HP Photosmart C6180 printer doesn't
The problem is with the print head and the , thin plastic signal cable that is attaches the print ahead to the printer. This part is not user replaceable and requires a technician to service the same.
As you have mentioned having run the HP diags. The test page , did it display yellow stripes or not.
Secondaly, if you have another computer at your place, or can check the printer on another system , it would help isolate the problem with the printer.
Thanks
proton
Posted on Oct 11, 2008
  • 313 Answers
SOURCE: DesignJet 5500, cannot get it calibrated
lubricate the rod using WD-40 and syrine, and recalibrate
Posted on Apr 08, 2010
mishrajk21
  • 202 Answers
SOURCE: HP Designjet 500, I have replaced the black print
it seems there r some air in ur ink tube *** inser the priming heads & done the priming & reinstall the print heads if problem not resolved replace the carridge assembly,,,,,,,,,
Posted on Jul 06, 2010
  • 8 Answers
SOURCE: print quality is bad. tried
You need a new print head. This is a common problem with KODAK printers. Call KODAK tech support and they will send you one for free.
Posted on Nov 15, 2010
Color calibration
Sounds like it is time to clean or replace your print head. It is also possible that the cartridge that you have is defunct. Try installing a new one. If that fixes your problem, the issue was the cartridge.
Jul 24, 2017 | HP OfficeJet Office Equipment & Supplies
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
Print quality is bad. tried cleaning print head, calibrating printer, nozzle correction & ink levels are fone.
Nov 11, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
HP Designjet 500, I have replaced the black print head twice, the first new print head would align and then fail the color calibration, the second new head aligns and pass's color calibration, but when I...
Jun 03, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
Print head moves but doesn't print.
make sure the knb level is set to 0 there is adjustment of head and roller distance .just adjust the lever .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Epson LX-300 Matrix Printer
Hi I've just replaced the ink cartridges thinking that the print problems were due to low ink - I've tried calibrating and cleaning the print heads but I'm only getting fain blue and grey tones printing...
These printer has a defect ... is the print head.. just call there support number they will replace the head.. I had to do it twice already. New problems is gone for a little while.. It wont hurt to try...
Oct 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Why will my new printer not read the ink level?
it is because the ink status monitor is not enabled in ur moms printer properties.enable it and u will be able to see the ink levels.
Dec 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
41 people viewed this question
k24674
jasbo
jasbo
