Question about Bang and Olufsen Beosound 2000 Shelf System
Hi my cd player on my beosound overture wont play and in the display where it says cd iluminated i also get this in the screen can anyone please tell me how to fix this problem thank u
5 Suggested Answers
  • 122 Answers
SOURCE: My BeoSound 4000's sound goes off while playing a
could be the r/c.the remotes are very powerful,take it into the next room and try again.maybe the volume down button on the units keypad is stuck down or faulty.
Posted on Jan 22, 2010
  • 122 Answers
SOURCE: How do I change the light bulb(s) on a BeoSound / overture
Remove glass doors,black panels 8 screws lift up cd clamper and detatch from drive bar at top l/h corner.Lift operating panel to gain access to cable connector behind keypad,this should provide enough room to work on lamps.
Posted on May 14, 2010
SOURCE: Beosound 9000 scratching top cd
You have to look up in the manual which way the two arrows on the underside of the unit are pointing when the CD player is located on the far right. The arrows are screw heads which appear in two holes on the underside. If, for instance, you are playing the unit lying flat on a shelf or table top, if you flip it up and forward to get at the arrows, the two arrows should both be pointing left. If you are mounting it on a wall, it's a different arrow combination. I had the problem you describe and this fixed it for me.
Posted on Jun 02, 2010
  • 122 Answers
SOURCE: Hi, I have a Beosound
IF THE DOOR SHUTS AND THE LASER ARM MOVES THE MOST LIKELY FAULT IS C2103 ON THE SERVO PCB.MAKE SURE THE CD IS CLAMPED PROPERLY BY THE CENTRAL HUB SPRING.
Posted on Nov 21, 2010
May 06, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Jan 14, 2010 | Bang and Olufsen Beosound 4000 Shelf...
Cd player wont work says no play
This problem occurs only when there is a lens problem so you please change the entire kit of the player that is tray with the motor lens to resolve your issue.
Mar 19, 2009 | Audio Players & Recorders
Bang & Olufsen Beosound 9000 - CD does not play
gently open cd player clean laser with a cotton bud and wipe all round laser part and lugs at top and bottom of unit
Feb 15, 2009 | Audio Players & Recorders
Owners manual
Below are links to the manuals. I also have this system with the original manuals.
Basically, press the "load" button to open up the CD mechanism, put a CD on the spindle, and press load again to close the CD mechanism. Press the "CD" button to start playing the CD. Page 12 in the User's Guide has instructions on configuring the radio presets.
http://www.beocollectors.com/usermanuals/beosound4000.zip
http://www.beocollectors.com/usermanuals/beosound4000guide_en.zip
Dec 18, 2008 | Bang and Olufsen Beosound 4000 Shelf...
B&O Beosound 1
Hi, It may be that the brushes on the CD spindle motor are getting dirty. A relatively easy fix, IF you know how to open a Beosound 1 without causing damage. I used to work in a B&O Authorized Service Center, and I suggest contacting the one nearest you first for an estimate. Most "normal" shops are most likely not prepared to handle the sometimes complex disassembly/reassembly issues.
Aug 02, 2008 | Audio Players & Recorders
CD Player
Thank you for your reply.
BeoSound 2000 - The CD won't even spin now. The cover closes, the Number 1 for the track appears in the display, then the cover immediately reopens showing what looks to be something like this [ ] in the display.
Nov 14, 2007 | Bang and Olufsen Beosound 2000 Shelf...
Won't play a cd
We have the same problem and are searching all over the web for a solution but no luck. If we find a solution we will come back and post what we found. :)
Oct 15, 2007 | Emerson MS3111M Shelf System
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
