Question about Air Purifiers
How to reset your android phone when locked - Air Purifiers
    New Friend:
  • 144 Answers
Tell me your phone model. There are way to hard reset it
Posted on Oct 25, 2013
Fresh Air Maachine by Ecoquest
I've read from some other posts on here that Ecoquest is good about returning the items and replacing them.
Jul 12, 2008 | Ecoquest Fresh Air Air Purifier
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
Need to reset my homedics hepa air cleaner
Press the lit reset button indicator and hold it for some time (I think it's like 5-6 seconds at least)
Oct 24, 2011 | Homedics AR10 Air Purifier
It will not turn on it says it locked how do i get this off of the screen and get it to turn on quiet flow is the nameof it
Crystal, first turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging the unit back in. After you plug it in, turn the Master ON/OFF Switch to ON and set the controls as you wish. Hopefully, during that 12 - 15 minute timeout, the unit reset itself and should now work normally.
If that doesn't solve the problem, you can call Hunter Technical Support. In the US dial 888-830-1326.
In Canada dial 866-268-1936
Apr 15, 2011 | Hunter Air Purifiers
Digital display is locked and will not turn off
Have you held buttons one and two down at the same time, or buttons two and three, or one and three? There is probably a reset sequence that you might give a try. Also look all around it for a rest button. it would be as big as the head of a pin in either black or grey.
Dec 02, 2009 | Air Purifiers
Defender air purifier
If you have replaced your main filter you need to reset the red light. If you have not replaced the main filter you will need to contact your local filterqueen distributor. If you go to www.filterqueen.com they will direct you to your closest distributor and they can walk you through over the phone on how to reset your red light.
Feb 15, 2008 | Filter Queen Defender Air Purifier
Bionaire filter replacement- reset indicator
It worked - the solution to press sleep and the power button simultaeneously worked! Air cleaner then reset to 99%. Thank you Harbourman!
Oct 31, 2007 | Bionaire BAP1175-U Air Purifier
Air Purifiers Logo
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
