Question about Maytag MDE4806 Electric Dryer
I have a Maytag epic Z MED600TW1 DRYER and when I press START Button I can here a control switch click inside the dryer housing but the dryer does not start. I then press cancel and it clicks to cancel the dryer cycle then I press START again and it clicks again and still no actual starting of the dryer begins. Is there a way to run a self diagnostics on the this model so I can determine what is malfunctioning?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 93 Answers
That it the start/run winding in the motor
Posted on Oct 21, 2013
  • 409 Answers
SOURCE: Maytag Epic dryer won't start
hi there,
if it beeps it means that the keypad is sending a signal to the control board to start it but it doesn't. since the control board sends a signal to the motor to start the dryer to spin. does the dryer hum?
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: Flashing "touchup" and dryer won't start
What I did was unplug it for 1 min., plug it back in. Push the "off" button once, then push the off button again and hold it for 10 seconds. This is supposed to reset the computer. It worked for me.
Posted on Nov 14, 2007
  • 31 Answers
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
Your motor has fried. It isn't in the Control Panel, the SENSES light wouldn't turn on if it were the CP. If you go to your closest Home Depot, ask the front desk for assistance with Dryer Motors. They will guide you through to get you the right one. They will even tell you how to install it. When you replace it with the new motor, the Dryer will work fine.
If this helps at all, please rate this a FixYa. - Evolution
Posted on Jul 17, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Posted on Nov 05, 2008
  • 36 Answers
SOURCE: Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Posted on Jan 02, 2009
Control board sparks, smokes and smells when trying to start
Did you have a lightning strike near by? Or power outage with a power surge. Could have shorted the board.
Mar 13, 2015 | Maytag Epic MGD9700S 27 7.3 cuft. Gas...
Maytag epic z power button wont start machine
Maytag dryer. has no start check door switch. if not door switch then its your relay board that may be bad also check all stats.
there will be 2 at blower cage and 2 on heater assembly
The 2 on blower cage one of these are a resister stat has to be exact resistance or dryer wont start or will start and then shut off dryer b4 it is completed drying hope this helps there should be a cheat sheet paper work that will help you diagnose your problem fallow the steps if not with dryer can be viewed online
Jun 25, 2014 | Maytag EPIC MFW9700S Front Load Washer
Electric dryer not get heat
Inspect the front door lock if "F22" is displayed. Press the "Pause/Cancel" button two times. Close the washer door firmly to latch the door. Remove clothing preventing the door from closing and latching. Press the "Power" button, followed by the "Start" button.
May 12, 2012 | Maytag Epic 7.0 Cu. Ft. SuperSize Capacity...
Maytag Epic Electric Dryer will not start, turns on and when you push the start button it gives me a series of beeps and then the lights by the different cycles blink, but will not turn on. Was working...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 17, 2011 | Maytag Dryers
Maytag epic Z dryer. I hear rapid beeps when I press the start button and it won't start, no matter what setting I try. The door is firmly shut and the lint tray is clean.
heatman101
May 20, 2011 | Dryers
When I press the start button it doesn't go on. I have power.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Jan 26, 2011 | Maytag PYE2300AY Electric Dryer
Maytag dryer wouldn't start. Model number is: mde9700ayw. Problem: Although dryer was set to warm/cold dryer dried the clothes on extreme high temperature. For the second load of clothes, dryer couldn't...
HELLO THERE
I would have the board tested first and if it does indeed test out good than please try these things.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 31, 2010 | Dryers
Maytag Bravo 400 series won't start. I click the start button and it beeps but nothing happens.
Well first of all you can check door switch - If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. The door switch is a simple on / off switch to indicate whether the dryer's door is open or closed. The dryer will not operate when the door is open. If your dryer runs with the door open, the switch may shorted closed or there may be a dangerous electrical short in your dryer. If your dryer will not start when you press the start button and you hear no sounds, the door switch may be the problem.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Maytag Dryers
hi there,
Dec 17, 2008 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Maytag MDE4806 Electric Dryer Logo
158 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
