Question about Dell Dimension Computers & Internet
Dell dimension 3100 win xp home will not logon or go to setup/boot screen, only goes staight to black screen saying TYPE SYSTEM PASSWORD AND PRESS [ENTER] but it doesn't let you type anything. Also will not run cd or usb just goes to enter sys password screen HELP.
    Master:
  • 359 Answers
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
Posted on Oct 20, 2013
LMITC
SOURCE: Blue Screen c000021a
boot system into safe mode. locate the icon for my computer. right click and go to properties. locate the computer name tab and select it. find the radio button for "change" and click it. rename the computer to something considerably shorter then what you have. the system cannot boot and complete the logon process if the computer name is longer than 200 "bytes"
Posted on May 27, 2009
SOURCE: Dell Dimension Startup
disable the floppy drive in bios and try to go to safe mode
Posted on May 14, 2009
Drummernick
  • 440 Answers
SOURCE: Dell 4400
format hd reinstall windows ok or buy new hd
Posted on Feb 09, 2008
wipdhuls
  • 133 Answers
SOURCE: dell dimension L800CXE
Hello Wademyd,
It seems that the installation CD that you have is not a bootable CD.. must be old one.
Please down load the boot disk for windows from http://www.bootdisk.com or follow the Microsoft article link given below:
http://support.microsoft.com/?kbid=310994
Do not be intimidated by the article, although it looks big but there is very little that you need to do, rest of it is general instructions like where can you order a new CD from etc...
OR
Simple solution is to borrow Bootable Windows XP installation disk and install it using the serial Key that has been given to you.
Please let me know if that helps and please rate the solution if it helped you.. it will not cost you anything but will make a difference for me :)
All the best and kindly let me know in case you need any further assistance.
Regards,
Srinivas
Posted on Jun 11, 2009
  • 597 Answers
SOURCE: Dell Dimension 4700 can not boot, can not enter
Try a different keyboard. Maybe the one you're using isn't working and doesn't allow you to get into the setup. One way or another it sounds as if it's not seeing the hard drive. Hard drive may be bad or it's not connected properly
Posted on Nov 05, 2009
Dell dimension 3100 wont load to main screen
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 29, 2012 | Computers & Internet
I have a dell dimension 3100. it worked fine and i let someone borrow it and when i got it back it just goes to a black screen and says "enter system password" then "press enter" i...
Your "friend' probably put a BIOS password on your computer. Find and disconnect or remove your BIOS battery on the mother board. You may be able to slip a business card under the contact on the top effectively removing the power from the BIOS. Let it stay disconnected for 5 minutes. Reinstall and reboot.
If this doesn't fix it, you will probably have to get professional help at your computer dealer or repair shop.
Lesson learned: Don't lend your computer or your spouse to your friend.
Thanks for your visit today.
Jan 30, 2011 | Dell Dimension 3100 PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
It went to welcome screen and after i typed in my password, got a black screen that says insert disk and press F1 or press F2 and something about setup.
This happens whenever one closes any installation prematurely. Insert the disk then properly cancel or complete the setup and restart the computer you wont get this message.
Jun 22, 2010 | Dell Dimension 2350 PC Desktop
I have a dell dimension 5100, although i did not put in a password, at the logon screen each logon is asking for a password! please help before i hit it with an axe!!!! Paul
If you let me know the Operating system type, i can help you better, well try this.. actually this is for windows Xp, when you get onto the logon screen, press "ctrl+alt+delete" simultaneously several times, you'll be presented with a different logon screen (dialog box), type "administrator" in the logon name and press enter/Ok. I hope that you've tried blank passwords. Anyway Good luck and let me know the operating system type if you still get time before you turn into the real ....
May 27, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Black Screen on Dell Dimension 3100 on boot up. Running Windows XP Home Edition. This happen before you get to the Windows login screen.
If you have a black screen it means the system cannot boot into your master boot record, you should reinstall the system using a bootable Windows XP CD, and perform a repair,( not the Repair Console).
When youre in the Windows XP Wizard screen, press enter , accept the license agreement, and then it will check for existing windows xp partitions, press R to repair the existing Windows XP installation, and wait til it gets your system restored.
Jan 10, 2010 | Computers & Internet
Boot issue
Start the computer and logon as normal,Once on the desktop,Click start,run,and type msconfig , Click OK, On the General tab,Choose Boot normally,Click apply,The computer will restart,click ok.
If this don't work,Post back
May 15, 2009 | Dell Dimension 3100 PC Desktop
try going into your BIOS and changing the boot sequence, it may be set to boot from floppy instead of harddrive. or you could just reinstall windows, but that sucks cuz then you lose all your data and programs. and not to be rude, but you shouldnt have bought a dell, they are full of problems.
May 11, 2009 | Dell Dimension 3100 PC Desktop
Formtting my hard drive
if you are formatting your computer for the first time and if you bought your computer after 2005 then just press <Ctrl> + <F11> keys right at the dell logo on startup, you will boot to dell PC restore. This will restore your computer back to the factory settings including WinXP, all the drivers and softwares.
If you bought your computer before oct 2005: then follow these steps.
1) start you computer and at the dell splash logo tap <Del> key to enter setup. (restart and retry till you see entering setup)
2) select Boot from the tabs above using arrow keys.
3) select boot device priority press <ENTER>.
4) select ATAPI CDROM, <ENTER>.
5). insert WIN XP CD in the top drive of the computer and press <F10> select yes.(this will restart your computer).
6) after reboot you will see " press any key to boot from CD" press any key within 5 sec on this message.
7) Press <ENTER> to install
8) Press <F8> on next screen
9) Press <ESC> on next screen(Options may vary on this screen , read instructions).
10) select partition using arrow keys press <ENTER>
11) select NTFS/NTFS quick, anyone. and press F on the next screen...
this wil start WIn XP set up and concludes the formatting of the HDD with Win XP CD.
Apr 28, 2008 | Dell Dimension 4500 PC Desktop
Computers & Internet Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
