Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
Cracking sounds from top of refrigerator compartment of a 7 year old WSE6070WA
  • Westinghouse Master
  • 5,323 Answers
I would suggest looking at the fan if there is ice build up it could be inhibiting the fans operation, or fan hitting the ice and clacking
Posted on Feb 22, 2015
  • 31 Answers
Had the problem in a similar fridge - the repair person said the noise was most likely the sound of ice build up being removed during defrost cycle and not to worry. Suggest you check the freezer temperature is not too cold and building up excess ice.
Posted on Jun 17, 2014
I have a LG fridge double door top freezer model no GL-T262QM. the refrigeration compartment is not cooling.
ihave a lg.double door refri model T262QM about 7 years old. no cooing in freezer so i want to get cooling coil capaliry data i am technician
Mar 21, 2011 | LG LRTN22314 Top Freezer Refrigerator
Our refrigerator is about 7 years old. The vegetable drawers (clear plastic) are very difficult to pull out. We have washed and dried them, cleaned the tracks, etc., but to no avail. Is there a...
Normally, all vegetable doors can easily be pulled out as there are minimum 1/8" allowance in both side. I think, your refrigerator got corroded with where indoor compartment is fixed. Please check any dental in iron side of the door, If not, just clean drawers both side with an emery (salt) paper to enable it to enter inside freely.
Jan 22, 2011 | Amana ARB8057C Bottom Freezer Refrigerator
I have a new Frigidaire 20.6 cu. ft. top freezer without icemaker. When it turns on or goes in its cycle it makes a knocking sound behind freezer compartment, then stops. is this normal? . P.C Richards...
This is normal. It is the sound of the refrigerant flowing through the coil on start up. This will cause the knocking sound you are hearing. It should only last for about 7-10 seconds. You might also hear a cracking noise due to the insulation expanding and contracting due to fluctuating temperature. Refer back to your owners manual under normal operation sounds. Hope this helps.
Oct 20, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
AMA BX21 7 years old Came home found freezer warm and thoughted, top referigator was still almost cold, have bben gone 5 days---the compressor keeps trying too start but cuts off after 30 seconds ,...
Look inside the fresh food compartment. Behind the temp. control cover is a defrost timer. Yours may have a small opening that you can put a pencil eraser in and turn clockwise. When you do that the refrigerator should begin cooling again. I will be here to help you get your refrigerator going with diagrams and part numbers, Thanks, Sea Breeze
Apr 20, 2009 | Amana ARB8057CSR Bottom Freezer...
WHERE DO I FIND A REPLACEMENT TIMER DEFROSTER FOR FRTC03L3DS0 ... FRIGIDAIRE MANUFACTURED BY ELECTROLUX ... SMALL REFRIGERATOR WITH FREEZER COMPARTMENT SEPARATE APPX TWO YEARS OLD ... STOPPED COOLING ......
Could you recheck the model number for your refrigerator. The number you listed is for a oven. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Thanks, Sea Breeze
Mar 27, 2009 | Electrolux Refrigerators
Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Mar 06, 2009 | Whirlpool ET1FTTXK Top Freezer...
Fridgidare/Electrolux top freezer not freezing fan stays on.
Look for ice buildup on the back wall of the freezer.
If ice is there you have a defrost parts issue.
If not, check the compressor to make sure it is running.
Mar 04, 2009 | Electrolux Refrigerators
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Oct 13, 2007 | Refrigerators
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
91 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
