Question about Taylor Instruments Taylor 1442 Digital Recording Thermometer with Dual Probes
I have a Taylor 1442 digital thermometer the keeps peeping and the face is blank. Is there a way to reset? Thanks
The Thermo temp flashes HHH ....and the thermometer keeps beeping...??? What do I do!?
That means the temp is higher than the unit is able to detect. If it has been exposed to very high heat then it is damaged. It may still have a bad sensor.
Jun 19, 2016 | Taylor Digital Cooking Thermometer
How can i stop the taylor 1341 digital thermometer from beeping.
remove four screws on back of unit,cut red wire going to round beeping speaker inside lower front faceplate. problem solved it will never beep again but still read temp correctly.
May 19, 2014 | Taylor 1431 Digital Wireless Thermometer
Installed new batteries, but need instruction to reset temperature readings
Type "Taylor 1524 manual pdf" in google. That should pull up your manual. Sometimes companies produce the same item, with just subtle changes (product differentiation) i.e. Chevy used the same motor block for the 327,350,400 chevy motors, and just installed different cylinder heads.
Apr 22, 2014 | Taylor 1524 Wireless Indooroutdoor...
It says LL under current temp. What does that mean
That means that sensor believes the temp to be LOWER than it can read. Could be a bad sensor. If there is a reset button on the sensor use that to reset the device.
Sep 23, 2013 | Taylor 1479-21 Digital Thermometer
Taylor 1431 Digital Wireless Thermometer beeps at random intervals. Is there a way to silence it?
yes there is a solution to stop the beep. Take a piece of cotton and put into ur ears..... simple
Jul 05, 2011 | Taylor 1431 Digital Wireless Thermometer
My TAYLOR 1468 thermometer keeps beeping, how do I get it to stop?
The Taylor 1468 thermometer has an "ALERT" button on the back of the unit. This will control the beepin.
Jerry
Jun 05, 2011 | Garden
Current temperature on Taylor TruTemp 3528 reads "LLL"
It needs calibrated. LLL (low) means you need to put the probe in a glass of ice water. It will then say HHH (high) means you need to put the probe in boiling water, don't let the probe touch the sides of the metal pot of boiling water.
May 07, 2011 | Taylor Instruments Taylor TruTemp Digital...
Can't reset Taylor 5367 indoor/outdoor thermom
I changed the batteries on mine and it reset itself. That was easy.
Dec 09, 2009 | Kitchen Appliances - Others
APPLE IPOD SHUFFLE UNKNOWN ERROR 1442
I found a way to solve this, you have to google for a program called ipod reset utility or, you can search here:
http://support.apple.com/kb/HT1238
Either way, install, follow the instrucions and you can probably save your ipod (note; I saved my ipod on a mac. Haven't tested transfering songs from my PC an this moment)
Sep 09, 2008 | Apple iPod shuffle MP3 Player
Taylor Instruments Taylor 1442 Digital Recording Thermometer with Dual Probes Logo
Top Taylor Instruments Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Taylor Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
