Question about Ariston Technologies Dishwashers
Ariston LBF 51 Dishwasher. Detergent dispenser does not open
bigg t
  • 640 Answers
SOURCE: Ariston Dishwasher Detergent dispenser
you have 2 options.replace the timer on the unit or when you start a load wait 10 minutes and put a half cup or a little more of detergent into the water in the dishwasher.
Posted on Jan 05, 2008
Timon90
  • 126 Answers
SOURCE: Dishwasher detergent dispenser
You need a new PCB for your machine. And a wax-motor. Maybe a new dispenser too.
Posted on Jan 28, 2008
Speed boy
  • 76 Answers
SOURCE: whirlpool, quiet wash plus, dishwasher
You should see if the timer finished its cycle,some of them dont open till the cycle is comp.
Good luck.
Posted on Sep 09, 2008
poisnscorp
  • 111 Answers
SOURCE: Dishwasher Detergent Dispenser not opening
An automatic dishwashermag-glass_10x10.gif detergent dispenser door can become stuck for a few different reasons. Some problems are easy to fix, while some require more work. Repairs are basically the same no matter what brand of automatic dishwasher you have, although specific parts might be required. Fortunately, even if the detergent dispenser needs to be replaced, the problem is not an emergency. The dishwasher will clean dishes fine even with a stuck detergent dispenser.
    Fixing a Stuck Automatic Dishwasher Detergent Dispenser
  1. Step 1 Move the basket that holds silverware as far from the detergent dispenser as possible, or make sure no tall items are blocking the dispenser. Also, keep other items such as plates and pans away from the dispenser. Anything that winds up touching the dispenser during the wash cycle can cause the dispenser door to stay closed. Run the dishwasher to see if this solves the problem.
  2. Step 2 Remove the front door panel according to your instruction manual, or find the manufacturer's instructions online, which will probably be in a PDF file. The panel is typically held on by 6 to 8 screws along the edge, which you can see when the door is open. With most models, you won't need to remove the screws at the bottom of the door, which are part of the hinge assembly.
  3. Step 3 Clean the detergent dispenser thoroughly from the inside of the dishwasher and the exterior side as well. Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.
  4. Step 4 Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
  5. Step 5 Purchase a new switch if re-aligning the old one does not fix the problem. Typically, these switches cost under $10. See Resources for a link to different manufacturers where you can buy the part.
  6. Step 6 Label the two wires connected to the switch so you can correctly reconnect them afterward, and then remove them from the terminals by holding the slip-on connectors --- not the wires --- and pulling firmly. Use a pair of needle-nosed pliers for a better grip. Then remove the switch from the dispenser by removing the screws holding it in place. Connect the wires to the terminals of the new switch, and attach the new switch to the detergent dispenser. Replace the door panel.
  7. Step 7 Run the dishwasher again to see if the switch replacement has done the trick. If not, decide whether to replace the entire dispenser according to the manufacturer's instructions, or call a repair technician.
Posted on Nov 14, 2009
  • 160 Answers
SOURCE: The detergent dispenser on my Ariston AS100
put unit on a quick wash as the dispenser opens early in the cycle .. if it heats and the dispenser is still closed then a new dispenser is in order...
Posted on Dec 17, 2009
Why Ariston lbf 51 lights flash rapidly
24501406-0h3kxpflbez5mdeb5anq3st4-3-0.jpg If flashing any of the 4 LEDs (see picture) means that the dishwasher discovered a malfunction. Depending which combination of LED flashes (one LED, two LEDs, three LEDs or all four LEDs) indicates the specific error code.
Dado
May 25, 2014 | Ariston Technologies Dishwashers
Jan 05, 2008 | Ariston Technologies LL64WNA Built-in...
LBF 51 flashing lights
Hi
Is this the first time you are operating your dishwasher or if you have already operated it before go for the instruction manual of your machine which could possibly solve your problem.If you don't have the instruction manual don't worry i have attached a PDF of the manual go through it.Hope it solves your problem.If it doesn't i would recommend calling the technician to avoid further problems.If any other issue occurs please reply.Please rate me if my solution helped you.
You could have your instruction manual here.just click on this link.
http://www.dishwasher-manual.com/manuals/hotpoint-ariston/Hotpoint-Ariston_LBF_51.pdf
Regards,
bonefirediv.
Apr 12, 2014 | Ariston Technologies Dishwashers
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
Hi, I have an Electrolux E600 dishwasher and the detergent dispenser door has stopped opening. There's definitely nothing blocking it (the solution given in the manual). Any ideas appreciated. Tha
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replacedIf the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Apr 05, 2013 | Electrolux Dishwashers
Dishwasher dispenser will not open. I've been using the detergent tablets and am wondering if I should be using a liquid or powder instead?
Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
http://www.appliancerepairlesson.com/2011/01/29/dishwasher-soap-cup-dispenser-replacement-dishwasher-repair/
Good luck
www.ApplianceRepairLesson.com
Mar 05, 2011 | Whirlpool DU840CWD Dishwasher
The detergent dispenser on my Ariston AS100 Dishwasher will not open automatically any solutions please
Nov 25, 2009 | Ariston Technologies L63 Free-Standing...
Dishwashers Logo
64 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
