Question about Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract
Clutch chatter - Replacing the drive belt helped a little. Is there a way to adjust the clutch?
  • 351 Answers
There is no clutch as far as I know on ride on mowers, there is just a tensioner pulley that works off the brake/clutch, to adjust it you have to depress the brake/clutch to take the tension off the belt then adjust the belt tensioner to apply more pressure on the belt. Also check the tensioner pulley as I have found that they split in two and the belt becomes loose as a result.
Hope this helps
Posted on May 27, 2014
  • 59 Answers
SOURCE: Mower will not stop when clutch is depressed
When you replaced the belt you either got a shorter belt or you have rerouted the belt wrong. You might try and get an original; belt and replace the one on the tractor. Good Luck-David
Posted on May 27, 2009
panilling9
  • 284 Answers
SOURCE: drive belt keep falling off
you have belt guides near your pulleys that helps to keep the belt on during no engagement
you need to check to see if they are missing or bent and adjust as close to the pulley and belt as possible without interfereing with the belt and pulleys while engaged.IE: no rubbing against the pulley or belt while engaged or moving.
Posted on May 31, 2009
  • 110 Answers
SOURCE: I think I have a bad clutch since trying to push
If the engine dies when the clutch is released, you probably have a bad seat switch. This is supposed to kill the engine if you get off the machine while the brake is off. If the seat switch is bad, the machine will behave as iff you are not 'on board', and kill the engine if it's in an 'unsafe' condition.
Apart from possible needind a new belt, if the transaxle still has gears, it's unlikely you have done any serious damage.
Posted on Mar 10, 2010
  • 3911 Answers
SOURCE: I have a Craftsman mower
I don't quite get you, if the belt is running but the rear axle is not turning then your transmission is shot. If the belt is running and the rear axle is spinning with no forward or backward motion, then someone took the back wheels off and put them back on without installing the keyways.
Posted on Sep 20, 2010
richroth
  • 9472 Answers
SOURCE: i need help replacing the
The drive belt connects to the fron of the machine Just above the PTO clutch. connected to the vertical crank on the engine. It slips through a series of pullies to the back side od the mower. One pully will be on a tention spring. that is your golden ticket to getting the tention you need.
hello sir,
Looking at the pullys. for routing your new belt. V pullies for the inside portion of the belt and flat pullies for the outside.
You can usualyl take the chassis and pedals off as needed. the pebals have pins holding them on.
the seat has a safty switch that gets unplugged.
There are bolts hidden under the foot map as well which snaps up and down careful with these as that mat will never be the same if you break the clips.
THe back of the mower near and above the gastank you will see a pull thats ontop of a hydrostatic pump thats the last pully.
I have done these before without removing the body. However its not easy and you had better be limber.
Ohh and of course remove any decking under the mower or drop it all the way down for easier access.
Posted on Dec 24, 2010
2005 Honda VT 750 Shadow Aero making a chattering sound
Hi, Anonymous I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Rear Chains---RATTLE
5. Cam Chains---CLICKIT
6. Clutches---CHATTER
7. Cylinders---PING
8. Fairing Panels---WHISTLE
9. Fronk Forks---Plunk
10. Gears---WHINE
11. Head Gasket---HISS
12. Hydraulic Lifters---TAP
13. Pistons---SLAP
14. Radiators---GURGLE
15. Rear Chains---RATTLE
16. Rear Shocks---SQUEAK
17. Relays---CLICK&BUZZ
18. Shaft Drives---WHIRR
19. Shifting Trans---CLUNK
20. Solid Lifters---TICK
21. Starters---CLICK
22. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2005 VT750C Aero Engine Noise 2005 VT750C Aero Engine Noise
Clutch Noise SS750 Shadowriders
Honda 1998 VT750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Jul 11, 2014 | 2005 Honda VT 750 Shadow Aero
Bmw E36 Problems
The clutch relies on the pressure between the pressure plate and flywheel. If the pressure is too low, due to weak springs, or worn surfaces, the new disks will be prone to fail. Oil from a bad rear main seal will wipe out clutch components, as well as an improperly adjusted clutch, or bad driving (not you though)
On the hind side, overloading the clutch will wear it also. Shifting too early, bad brakes or bearings. Towing, or the wrong replacement parts. Do this, in high gear, on the highway, step on the throttle. Does the clutch slip? Too weak of pressure. Vibrations or chattering? wrong parts, Oil, or overheating from load. Burning smell? Something is loaded on the driveline or you need to get advice on clutch use. Just sayin for a newbee. Did you turn the surfaces when you changed the clutch? New pressure plate? Clutch disk? Proper Adjustment so it is not engaging? Parking brake not stuck? bearings or brakes hanging?
Oct 31, 2013 | Cars & Trucks
Clutch feels like it is slipping while driving
Sounds more like clutch...timing belt no.
Sep 05, 2012 | 1994 Ford Ranger Supercab
I noticed there is threaded adjustment on the clutch pedal push rod going into the clutch's master cylinder hydraulic system. Is this one way I can adjust the hydraulic clutch on my 1998 suzuki sidekick...
Yes, if you need a little oomph out of the pedal, you can get a little more throw out of the adj rod, or you can get a little less, it doesn't take much to move a clutch. Depends on what the clutch is doing, chattering, slipping, grinding, not shifting. You know, that kind of stuff all gets different adj. Check it out.
Jul 07, 2010 | 1998 Suzuki Sidekick
1997 f150 4wd with 4.2L and M5OD. Clutch is chattering or skipping a little at low rpms, when thing warm up it seems to be fine?
Pressure plate maybe on the thin side and is slipping on the flywheel. Suggest replacing the clutch pressure plate and thro out bearing.
May 18, 2010 | Cars & Trucks
Clutch needs adjustment
as the clutch wears the "free pedal" is reduced ... its easy to adjust "free pedal" and important to do so .. when there is very little or no free movement above where the clutch engages/disengages then the clutch starts to wear rapidly ... if there are no other symptoms like clutch chatter, slipping or noise then the clutch plate likely has some life left if it is adjusted properly and promptly ..
Feb 22, 2010 | 1994 Nissan Pickup
My '98 Escort ZX2 has 175,000 miles. I recently noticed a grinding or chattering with the clutch pedal depressed with the transmission in first gear. While stopped at a light the car suddenly began jumping...
Hi:
You need to check your clutch master cylinder reservour, not your brake cylinder. It is located approx in front of the clutch pedal, outboard of the brake cylinder. If it is low, you need to inspect for leaks around it, the lines connecting it to the clutch slave cylinder that is mounted on the transmission.
Dec 05, 2009 | Ford Escort Cars & Trucks
Clutch slipping on 2004 350z roadster
This is a Hydrolic System ,thus there is no Adjustment for what you discribe, You will need a New Clutch Assemble. I Recomend replacing ALL Clutch Parts while Trans is out. Uncluding All the Parts Listed Reliece Bearing, Clutch Disc, Pressure plate,And Renew Slave Cylinder FLUID.
Jan 24, 2009 | 2003 Nissan 350Z
Clutch noise
It's called "chatter",my xl600 honda does the same thing when I use the WRONG oil,OR-the engine gets very hot from over slipping the clutch,new clutch plates are in order when it starts "chattering.
Dec 18, 2008 | 2001 Yamaha Serow 225 WE
Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract Logo
114 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
