Question about Dometic Refrigerators
My fridge does not work on ac or dc - Dometic Refrigerators
  • Greg Stevenson
    Greg Stevenson Oct 22, 2013
    the fridge is an rv type dometic it works fine on gas after i hand lite it but will not work on ac or dc. I'M
    Top Expert:
  • Dometic Master
  • 5,061 Answers
If voltage remove thermistor from back board let run overnite if not ok bad cooling unit if ok replace thermistor if no display bad board
Posted on May 27, 2016
How do I fix a mini fridge that works on dc power but not ac?
Sometimes different cord configurations are used for dc operation and ac operation. It also possible that the 240v circuit is defective so that even with the correct cord connected the cooler won't work.
Jul 16, 2014 | Krups Gusto 880-42 Espresso Machine
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
Norcold DE704D won't switch to AC
http://www.thetford.com/LinkClick.aspx?fileticket=slRtJeja7H4%3d&tabid=497&mid=1316
This link will help with testing and resolve your problem. Can not resolve without these tests.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Refrigerators
DO YOU NEED BOTH AC AND DC CORDS TO MAKE IT WORK?
one cord is all you need if it works . the ac cord might be bad . but most likely the cooler is bad ..... i am a ****** for these coolers i have had a few (4) i have none now all of them burned up and stopped working or cooling and when it does work all you get is 20 degrees below outside temp every time does not matter if its the one i bought in 1990 ( that kept killing my battery) or the last one i had bought in 2005 that one was better it cooled 25 degrees below the temp in the truck a little cool but hardly close to cold and lasted about 6 months ........ dont spend a lot on a cord , you will be sorry .... myself i think i will wait another 10 years or so before i try again ... good luck
Mar 26, 2009 | Thermos Stainless Steel Gas Grill
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Dometic rv fridge
Your possibly getting a DC voltage interuption Your convertor can be over heating causing a temporary drop. You can chech this by turning everthing dc supplied on and watch to see if the check light comes on then. Primary is electric and if no electric then it is suppose to look for gas.
May 29, 2008 | Dometic RGE400 Top Freezer Refrigerator
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
20 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
