Question about Fitness Technologies UwaterG4 Waterproof MP3 Player
My Uwater G4 won't turn off or play??? I pushed the reset button but that did nothing? Love the product while I am water running. Please HELP! ! !
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
It won't start. when I push the test reset button it attempts to come on for a second then nothing. I changed outlets and same thing happens. before I did this the water would come out of the nozzle...
Had a similar problem with a Karcher that I own, after a little troubleshooting it turned out to be the big plug end with the reset in it, I took the plug end apart and found the contacts inside had melted thus not allowing proper contact of the reset button, I opted for a cheap way out, instead of ordering a replacement reset plug assy i changed it over to a regular 3 prong gfi plug end, been working great the past few seasons,hope this helps
Aug 12, 2011 | Karcher Pressure Washer 1800 PSI 15 GPM...
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Creative zen 4GB will not turn on, only blue light!!
yeah i know. i love zen too!! let it run dry and try recharge.
worked for me once
good luck
Jun 30, 2009 | Creative Labs ZEN Vision:M Digital Media...
Mac Problems
You may need a new PSU.
Dec 17, 2008 | Computers & Internet
PUSH THE RESET SWITCH PROBLEM
hmm...maybe:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
May 04, 2008 | Panasonic NV-GS15 Mini DV Digital...
Fitness Technologies UwaterG4 Waterproof MP3 Player Logo
Top Fitness Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fitness Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
