Question about Antec Computers & Internet
Computer solid yellow light - Antec Computers & Internet
  • 4 Answers
You need to take it to a tech shop so there can see what the problem of that yellow light i think the yellow light maybe the protection light or wat go and see the technician guys...
Posted on Oct 20, 2013
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
My wireless printer HP Deskjet 3050 J611 is not printing even though the blue light is solid. The yellow light is on. What do I o
clear the print que of all jobs pending reboot the printer and computer your printing from double check in devicers and printers that your printer is set as default and then try again
Jul 12, 2012 | HP Deskjet 3050 All-in-One Printer CH376A...
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I have replaced the coil pack on my 2002 ford taurus with the 3.0 24 valve engine. I have no spark to cyliders 3 and 4. I have also replaced the electical connector to the coil pack as well. All 4 wires...
All 4 wires have power and the yellow and white and the yellow and black pulse with the test light, the yellow and red and the solid red wire have a steady light with no pulse. The PCM - engine computer is no good , driver (transistor's) in side turn the coil on an off . Burnt transistors .
Mar 30, 2017 | 2002 Ford Taurus
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
When i start my computer a yellow light comes on but nothing happens
looks like you may have a bad component on the motherboard. A solid yellow light means a faulty component. to further diagnose you can check the diagnostic lights labeled A B C D on the back of your PC. HERE is the link to what all the lights mean and possible solutions.
Aug 20, 2010 | Dell Precision 360 Workstation/Personal...
Hp computer. hard drive light is solid yellow ..non working
Hi 2xcapers
This could be a problem with your IDE or SATA cables that connect your Hard Disk to your Motherboard. Try replacing these before you try the next solution.
The constant yellow light usually indicates a crashed or non-functioning Hard Disk. You can take this to get repaired and only the data where the "Spindal Pin" crashed will be lost, otherwise the Hard Disk should still be fine. The screen does not come on during the event of a crashed or corrupted Hard Disk, so this is another indication that there is a problem with the Hard Disk.
Please remember to give this solution a FixYa! rating.
Happy Easter
BearWeb
Apr 12, 2009 | HP Computers & Internet
Broadband 2nd Light keeps blinking yellow and then a solid red Light
Ask your Paents to ring the company they connect with it seems to be emulating a disconnection for some reason?
Sep 05, 2007 | 2wire (1000-000057-000) Modem
Computers & Internet Logo
55 people viewed this question
Top Antec Computers & Internet Experts
Dimitar Todorov
Julie Endres
Larry Chandler
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
