Question about Sharp LC-32AV22U 32 in. LCD TV
I cant get to the menu without a remote to change from cable to antenna
I pressed the menu button on my remote and went to channels then I went to antenna scan and lost all my channels how do I rectify this problem?
just go to menu and choose turbo/maunal search or go to channels and press right arrow key on your remote it will revert back to its previous settings
Dec 06, 2010 | Televison & Video
I have a mitsubishi tv model cs27200 and I dont have a remote. I got a universal remote but it wont bring up the menu. I need to program the channels for cable. I only get local channels without bringing...
You would need to look up how to program that remote to your specific tv. I would look up the owners manual if you dont have it for the remote...and follow the instructions for it. However, you will have to directly use the tv to program it to the cable. The universal remote will only change the channels and volume for you. Use your menu button to bring it up, make sure its set to cable and not antenna, and use your channel + and - to navigate through the menu and vol + to select your option
Nov 20, 2010 | Televison & Video
How to get to menu without remote
you can only get the menu without remote, if the menu button is at the front of the television but if otherwise you can can get a all in 1 remote control for to get the menu of the television .
Thanks for asking...
Jun 03, 2010 | Panasonic PV-M2089 Combo
Cable/antenna
To change between cable and antenna on your TV,
Press Home to display the "XMB" menu.
pick "settings" on the menu
then pick "channel" on the next menu
under channel settings, select "on" for cable and "off" for antenna TV.
Your user manual is available for download and option printing at the following link :
http://129.33.22.12/release/KDL40XBR4.pdf
May 16, 2008 | Televison & Video
Switch to antenna mode without a remote
Can you access the menu on the front of the tv? Is so go into the menu setup and switch from cable to air then run the autoprogram to search your channels. If you cannot access the menu on the front of the tv then a remote will be required . Also if if your tv has audio/video jacks in the back of the set and you are not using them hook it up with those inputs for a better picture . Your have to push the input button to select that a/v input you used . Good luck
Feb 22, 2008 | Televison & Video
Need help changing from antenna to cable without a remote
have cable attached to the TV. But, I lost my remote so I cannot change the TV setting from "antenna" to "cable." There is no menu selection on the TV itself. Is there any way to do this?
Feb 17, 2008 | Daewoo DVN-14F6N 13" TV
Changing to "Cable" from Antenna without a remote
if you have a cable box, just put the tv on channel 3,or a aux input.[depending on your hook up] if it's cable without a box,go to the menu setup screen on the tv look for a air/cable setting, choose cable. then do a auto program search.
wg
Feb 16, 2008 | Daewoo DVQ13H1FC 13 in. Combo
Sony Trinitron KV-20VM40
You can't. Best solution = buy a universal programmable SONY
remote for about 12.00.................................T.
Nov 18, 2007 | Sony KP-44PX3 44" Rear Projection...
Channels
If you have a menu button on the front of the Tv, you could search for an autoprogram or channel search menu and select that. Otherwise a cheap universal remote might be needed. You also want to make sure it is selected to receive antenna and not cable channels.
Sep 03, 2007 | Sylvania 6427FF TV
How to change from video mode to cable/Antenna Input without a Remote
Alot of Zeniths have menu for that, have you tried to press the channel up button?
May 15, 2007 | Zenith A25A11D 25" TV
Sharp LC-32AV22U 32 in. LCD TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
