Question about Atd Tools (ATD3130) 130A MIG WELDER 115V 3130
My atd 37001 welder was welding along fine when it just stopped arcing I assume a part burnt out but which one and how do I find the part?
  • Atd Tools Master
  • 9,742 Answers
Check a fuse or circuit breaker. The breaker may reset it self when it cools down. The rectifier may be bad or the transformer opened.
Posted on Jan 16, 2014
I need tips for my stud welding gun. How can I replace them? Thanks John
https://studweldprod.com/
Stud Welder - Stud Welding Equipment, Gun - Stud Welders Machine
www.eastwood.com > Welding & Fab
  1. Cached
  2. Similar
Stud welding makes more sense. Our stud welder systems each have a stud gun welder that spot-welds a series of pins onto the surface of the dented metal.
What is Stud Welding? ' Sunbelt Stud Welding
www.sunbeltstudwelding.com/studwelding.htm
  1. Cached
  2. Similar
Weld studs come in a variety of designs, threaded, unthreaded, tapped, etc., ... The welding gun is activated and the fastener is welded in a fraction of a second.
Stud Welding Machines and Equipment ' Red-D-Arc Welderentals
www.red-d-arc.com/rental-equipment-subcategories.aspx?sub_cat=180
  1. Cached
  2. Similar
Red-D-Arc offers a range of fully regulated, user-friendly stud welders, stud welding machines and equipment available in single or dual gun versions and ...
Jan 30, 2017 | Welding Tools
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Weld arc not stable. Wire feeds, good ground,
Arc blow could be the cause! Put your ground on the work piece and weld away from it. If you weld toward a ground clamp the magnetic forces will blow your arc around sometime. When taking a cert this simple mistake can make or break ya on your cap or reinforcement beads.
May 09, 2010 | Hobart Handler 140 Mig Welder
NO arc or power on my Welder/Generator
check your back panel fuss and brakers
Oct 11, 2009 | Welding Tools
Trying to weld with Hobart 125 EZ
If you are using flux wire and not shielding gas, your clamp should be positive and the wire should be negative. Heat is provided by the electrical arc that happens between the wire and the material. Your welder by itself does not pre heat the material and with 3/16 material you should not need to preheat anyway.
The electrical arc is kept consistent by adjusting the wire feed rate and the current applied. You will need to experiment with these settings to find what works best with your welder. For this welder and 3/16 material, I would suggest you start at the upper end of the current scale and about a third of the way up on wire speed. The welder might have a chart for these settings in the manual or inside cover.
If the wire feeds too fast, it will push the probe around and you will feel pressure as the wire feeds out. If the speed is too slow you will get large spatters and intermittent arcs. When properly adjusted the arc will sound even and consistent. The arc gap should always be about 1/8 of an inch.
To maintain enough heat for good penatration, do not move the probe too fast, work in a pattern and watch the weld pool (melted metal) and not the arc. Watching the weld pool will clue you in if you are moving too fast or too slow.
I hope this helps.
-Scott
Feb 03, 2009 | Hobart Handler 125 Ez
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Dec 13, 2008 | Inverter 220 Volt Tig Arc Welder
Atd Tools (ATD3130) 130A MIG WELDER  115V  3130 Logo
109 people viewed this question
Top Atd Tools Welding Tools Experts
Bill Boyd
Are you an Atd Tools Welding Tool Expert? Answer questions, earn points and help others
