Sky com no signal when it rains - Televison & Video
Need to speak to Sky. Your LNB on the dish needs changing and possibly cables too, due to water damage. Speak to customer services they'll book and engineer visit for you.
Posted on Oct 21, 2013
Why is my sky+hd box not getting a signal?
Bad dish alignment. Rain or snow blocking the dish. Leaves on a tree blocking sight of the satellite. Scaffolding/building works blocking sight of the satellite. Fault on the cables. Damaged or faulty LNB
Sep 03, 2014 | Televison & Video
Tip
Watch your SKY channels on a second TV with Magic Eye and remote
If you have Sky Multi-room this will feed a separate SKY signal from your LNB on your dish to a second SKY box if you have the basic this will not cost you anything you still need a card inserted in the front to make this work. I think it costs £5 extra for more channels.
So if you have SKY + you will have 3 coaxial cables coming out of your LNB. ( 2 for the SKY + and 1 for the Multiroom )
To ger the signal for free the easy way is to connect a coaxial cable from the RF2 output on the back of the SKY ot SKY+ box into another TV and use a SKY Magic Eye these cost about £5 and have a range of about 20 meters. You can use a coaxial splitter to feed two TV but you will loose more signal the more you connect.
You will need to turn this function on using the hidden menu to allow you to use the Sky Remote control then LED on the unit will show you that there is a signal.
Press <SERVICES> <4> <0> <1> <SELECT> and goto the RF2 output to turn the signal on you might find that this signal is already turned ON for you.
Note: If you are using a multiplex faceplate unit this signal will not work as it relies on continuity of the coaxial cable with a 12V DC signal being sent out of the back of the SKY Box.
For all setups changing you Box model or adding an extra box SKY must to this for you by having your phone line connected so they can reprogram your Smart Card.
on Jan 30, 2010 | Audio Players & Recorders
Sky tv problems no signal
Thanks for the update.
Aug 02, 2014 | Televison & Video
No signal on sky
There may be a problem with your tv setup.Perform the following steps below:
1.Press the standby button on your Sky remote and switch off your Sky box at the mains. Check that the power light on the front of your Sky box is off before proceeding.2.Check your cable connections 3.Switch your Sky box back on at the mains. Wait 4 minutes before pressing the sky button .You may see a message before viewing resumes, on Channel 998.Tthat's it
Dec 09, 2013 | Computers & Internet
My sky says check signal..rain fade its been like this for an hour now...sky help
sometime we need to diagnose the problem by turning it Off and On again. try it.. are talking of wi_fi signal or network signal.. same solution..
Sep 21, 2013 | Cell Phones
Sky.com/nosgnal
I have no satellite signal
Dec 06, 2012 | Logitech QuickCam Televison & Video
Blue skies are splotchy. In all photos with blue or gray skies, the color looks like there is rain on the lens, although the lens is completely clean. This is severe and obvious. Photos without sky...
I had the same problem, when i check from repair people, they say that the CCD needs cleaning. I havent tried it yet, But going to do it soon. Will see what happens
Jul 13, 2009 | Konica Minolta DiMAGE Z5 Digital Camera
My Sky system says there is no satellite signal being received. Have tried disconnecting box etc with no improvement.What else can I do?
press services then system set up then signal test the signal strenth and qaulity should be about half way at least it shows up grey lock indicator should be ok if it shows not locked your dish has been moved and needs to be alighned do this when the weather is fine clounds and rain reduce the signal and may even stop it all together sky will charge you £65 to alighn the dish but you can buy a meter and do your self get 1 from bandq ebay maplins worth checking for breakes in the cable going from your box to the dish and if you can try your box on a friends dish just to rule out a faulty box of course there is a chance the lnb on the dish has gone faulty but you can get these cheap to or even borrow a friends to try unscrew the cable and look how it is fixed on useualy they just pull of but it might have a clip on or tape on
Aug 24, 2008 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
