Question about Whirlpool GERC4110PS Kitchen Range
Two left burners no working on GERC4110PS - Whirlpool GERC4110PS Kitchen Range
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Replace the fuse that relates to theses burners. If nor sure, replace all the fuses. ..noting first where each was taken from. The 30 amps are for the oven; 20 for the elements. 15 for the light.
Posted on Oct 21, 2013
Testimonial: "I already replaced fuses on panel and is the same"
Why would the left burner activate the right igniter?
Sometimes a lot of the holes in the burner get plugged. I use a toothpick to clean them out.
Hope this helps.
Mar 20, 2015 | Kitchen Ranges
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Only left side of burners working
If you have the Cal Flame burners that are straight, cast brass burners, there is a slot under neath the burners on the back end of the burners. This slot allows the flame to move from the left side of the burners to the right side of the burners. This slot in the burner will corrode shut and not allow the flame to move from the left to the right side. Sometimes you can scrape out the corrosion, and sometimes you can not. If you can't get the slot open, then you have to replace the burners. Cal Flame burners also have a reputation for warping.
Mar 04, 2012 | Cal Flame 4-Burner Drop-In Grill
Oven was running heard a large pop and tripped a circuit breaker.
sounds as if a wire or part has shorted causing circuit breaker to tripp.
Sep 28, 2009 | Whirlpool GERC4110PS Kitchen Range
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Jenn air range, model CVG4280B, repair, ignitor problem. Ignitors will not work on any burner. Burners can be lit manually. Power is available at the electical box. Fan comes on when either burner turned...
I do not know the cause BUT the fan behavior (on for left burners, off for right burners) is by design. The high-speed fan has two switches; 1) the primary switch visible centered between top two knobs, 2) secondary switches integrated with left burner knobs.
Apr 26, 2008 | Kitchen Ranges
Whirlpool GERC4110PS Kitchen Range Logo
65 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
