Question about ASUS HS-W1 Wireless USB Headset
How do i fix my HS-W1 charger connection issues. The cable plug wobbles about and has to be in certain positions else it wont charge.
Trying to charge battery for first time. It says connect two red connectors. Do you charge it first then connect the connector afterwards?
1. I assume this is a car battery so the first thing you do is to disconnect the vehicle cables from the battery terminals. The negative first and then the positive. The positive terminal is marked with a plus sign ...+ ... When refitting the cables to the
battery after it is charged you fit the positive cable to the positive battery terminal(+) first and fit the negative(-) last.
2. Now that the battery is unconnected from the vehicle you can fit the charging cables to the battery terminals. The charger you have should have 2 cables leading from it , a positive with a red plastic insulation on the clip and a negative cable probably with black insulation on the clip.The instructions with the charger will tell you in which order the cables are to be attached to the battery and the order you remove them. Each of the 2 cables has to be clipped onto the correct battery terminal. The positive cable(+) from the charger goes to the positive battery terminal (+)and the negative cable(-) from the charger goes to the negative battery terminal(-).
3. Once the cables from the charger are properly connected to the battery, you can plug in the charger and turn on the power.
4. Batteries generate explosive gasses when being charged and it only takes one small spark to ignite them. Don't reconnect the battery after charging for a half hour or so and make sure the area where you are charging is well ventilated.
Dec 18, 2015 | Cars & Trucks
Why does my headset turn on/off
Seems like what you say a power problem + the wireless band is a busy surroundig. Try some new batteries . It goes on so that's not the problem, it seems to me your signal is too weak to provide the working power and every day hours loading makes it die just faster.
May 18, 2014 | ASUS HS-W1 Wireless USB Headset
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
Every time i plug in my charger my phone wont charge and it turns on and turn off.........
Hi! kindly try to drain the power charges of the phone by disconnecting the battery from the phone unit. Connect back battery and make sure that the charger is connected properly on the charging port of the phone. Please make sure you are connecting to a stable power outlet.
Jun 09, 2010 | Computers & Internet
Mustek GSmart S50 Digital Camera wont turn on. Cant seem to charge the Li-ion battery. LCD Display wont turn on. Looking for suggestions to fix it, e.g. does a service manual (possibly downloadable)...
try first this ..for to see if the adapter/charger is to blame ..or the camera has a issue or it is the charger plug ...
This camera has the possibility to be charged from a computer in the usb mode...so ..connect the camera to the computer with the data cable ...than after you closed all the autoplay and whatever might start on computer ..click on the icon in the tray system ..and select remove ...but leave the camera in ...and on ...and look if it charging...anyway in the usb mode it is charging and may be a way to use it ..and if it does..it means that the charger is burned or the plug do not makes contact well..and either clean or change the plug ..after you measure the charger and see its working ...This way you eliminate them on eby one ...if it charges with the usb cable and powers on ..measn it is ok ..but a issue is with the charger ..and if this seasm to be ok when measured or tried with aanoter device ..than the only thing that remains is teh charger plug ..and you will have to change it ..
But , if with the usb cable r ..leaved on ....and off at the time about an hour or two ...and still not powers on ..it is probably another thing much worse ..the board or ..the battery ..and you have to analyze if it 's worth repairing ..
Jun 03, 2010 | Mustek GSmart S50 Digital Camera
Sony Ericcson t707 battery charge
has the battery been charged before the battery was flat? if yes this has cooked the battery and now needs replacing
Apr 10, 2010 | Sony Ericsson T707 Cell Phone
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Cect i9 wont charge battery is fine
the issue is with the wall usb ac adapter just replace it (with a better quality one) and it should work, you can also charge the phone using your computer. Well... this fix worked for me.
Dec 10, 2008 | Dual Electronics CECT P168 Cellular Phone
My iphone doesnt charge
Hi there!
There have been some reports of iPhone chargers going bad prematurely.  The test:
  1. Connect your iPhone to your computer via the USB cable.  Does it make a little beeping noise when you connect it, and then charge up?  If so, the issue is not with your iPhone or USB cable.
  2. Next, using that same USB cable, connect it to your iPhone charger.  Do you get the same connection noise and then does it charge up?  If not, the issue is probably with the charger.
Assuming you have a faulty charger, you are still well within your 1 year warranty from Apple.  Visit an Apple store (www.apple.com/retail) Genius Bar (make your reservation online before you go, to avoid waiting around), explain the issue and how you tested it out, and they will almost certainly replace the charger for you at no cost.
Oct 11, 2007 | Apple iPhone Smartphone
Wont charge
Look at your phrase "it only charged when i placed the chord in a certain position" ... This points to some kind of fault inside your phones charger-plug.
You can try fixing this by yourself by using this guide to dismantle your phone :
http://www.uselessinfo.pwp.blueyonder.co.uk/explodenok6670.htm
Only expanded view, but it should show you where to look.
Otherwise take it down to your local Service-Center and let them have a look at it, seems to be a pretty simple "operation"
Oct 09, 2007 | Nokia 6670 Handheld
ASUS HS-W1 Wireless USB Headset Logo
269 people viewed this question
Top ASUS Radio Communications Experts
ray gallant
Paul Chapman
Paul Chapman
Brett Duxbury
Brett Duxbury
Are you an ASUS Radio Communication Expert? Answer questions, earn points and help others
