Question about Microwave Ovens
Ge profile microwave oven door
I must slam the door on our GE Profile microwave to get both the light to go out and to get it to work. The ON button seemed to malfunction today so I took the cover off got the button working, but I am back to having to slam the door to get the light to go off and get it to work. What part(s) do I need to replace. Otherwise it works fine.
  • Microwave Ovens Master
  • 2,113 Answers
A micro-switch or two there are two or three in the door.
Posted on Oct 21, 2013
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE PRofile JVM1090
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Oct 22, 2007
stonephoenix
  • 563 Answers
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Posted on Feb 04, 2009
  • 10865 Answers
SOURCE: The door handle on my GE Profile ADvantium 120 Microwave is broke
You may consider using epoxy to "glue" the handle back into place. The epoxy will be stronger than the handle itself. If you do this get the one minute epoxy
Posted on Apr 27, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Posted on May 30, 2010
Ge profile microwave convection oven model 1790 troble shooting stop working
It may be a bad door switch or mount.
(Anybody in the home opening the door while it's cooking?)
See our help file on door switches here.
Mar 26, 2013 | GE Microwave Ovens
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
I have a GE Profile, built in 2007. The microwave functions precisely as expected (light goes on, it thinks its on) but the magnatron, fan and turntable dont run, but the controls count down as if...
I would suspect the primary interlock (upper door switch) or its mount has failed, probably due to door slamming or opening the door while it's cooking.
See these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If the switches check good, or you need further help, please feel free to let me know directly.
Jun 07, 2011 | GE JE2160 Microwave Oven
May 27, 2010 | GE Profile Spacemaker Over-the-Range...
My ge Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
45xs
May 12, 2010 | GE JE2160 Microwave Oven
Change inside microwave light GE profile microwave
open the screw and then full out the side and top cover
Apr 21, 2010 | GE JNM1851SMSS Convection/Microwave Oven
Absolutely. That's why they make shop bulbs to use in one's portable garage work light and garage door opener.
Slamming the door of a microwave is never good idea!
Another factor is touching the new bulb with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
