Question about 2004 Mustang Factory Wiring Diagrams
Can we replace a steering mount bush for toyota liteace noah 1999? Thanks
    Champion:
  • 473 Answers
Sure - buy the parts and install them.
Posted on Oct 21, 2013
I have a 2002 Toyota Noah. Its shaking the whole body when I accelerate. The shaking increases with speed. Does this Noah have Mass Airflow Sensor, if so where is it located?
has a mass air flow sensor
check engine light should be on if the maf is faulty
could be other EFI sensors
look for this part in the engine bay
Mar 30, 2017 | Toyota Cars & Trucks
My toyota noah refuses to revv and the fault code is p1632
Head over to this site please ~~> http://1999-toyota-noah.enginecodedb.com/p1632.html
Nov 24, 2015 | Toyota Cars & Trucks
I need a wiring diagram for 1999 Toyota Noah
Something must be drawing the battry flat. Probably something you can't see. Start by removeing glovebox light & boot light & see if the current drain stops. If it does one of those lights are staying on.
Jun 29, 2012 | Toyota Cars & Trucks
My chrysler voyager 2lt got problems with power steering fluid full but making whining noises and very heavy
Belts tight? If so check your steering rack unit for leaks (wetness) around ends of seals.Also where rack is mounted for loose bushings that rack mount in. Look sort of like stablizer bushings. Possible causes would be bad Steering Rack or pump itself.
Jan 24, 2010 | 1999 Chrysler LHS
Toyota liteace fuse box
Hi do this first in this order:
1. Locate your fuse box. ( should be under the drivers steering column or under the dash ect).
2. Usually there is a diagram on the fuse box cover. (usually in Japanese)
3. If you can't speak Japanese, that's fine just go through every fuse in the fuse box and inspect them all
4. Replace burnt out fuses with an identical amp match. (eg burnt 10amp fuse replace with new 10amp fuse). Simple.
Warning do not replace a burnt out fuse with a higher amp fuse as this may cause a fire.
If you continue blowing fuses all the time then there is something not right.
A lose positive wire may be arcing out to negative earth (car body). And causing you to blow fuses.
Its a process of common sense and elimination that will fix this problem.
Let me no how you get on.
Jules...
Mar 22, 2009 | 1990 Toyota 4Runner
1999 4Runner - front bushings replacement
It is only a stabilizer problem and I also suspect that you got bad tires. Also your steering rack can be checked on. Cheers
Jan 15, 2009 | 1999 Toyota 4Runner
2004 Mustang Factory Wiring Diagrams Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
