Question about Dryers
I have replaced the belt on my white knight cl447 tumble dryer and put all the pieces back together, the drum is now spinning, however there is a scraping sound coming from it. I think it may be from the back panel as I removed that when changing the belt. Any suggestions as to how this can be fixed?
  • 22 Answers
Just a suggestion sounds like the drum is not resting on the felt
Posted on Oct 20, 2013
  • David Mitchell Oct 20, 2013
    There isn't any felt there, I just read a solution to a problem on another post and it suggested a new rear bearing kit was the answer, thanks for the suggestion.
2 Suggested Answers
SOURCE: hotpoint tumble dryer is making
This sound is caused by the drum tilting towards the rear panel just above the heating element housing and is due to the drum spindle wearing through the bearing. (Which can lead to it shearing off) after it`s cut it `s way into the bearing support bracket. A new rear bearing kit is needed. it will come with a foam support which is stuck on to the inside of the back panel as the drum rests against this when turning. the foam support on your dryer may have perished or gone flat due to the heat from the element and that is why your hearing the scaping sound. new foam ring from the bearng kit will cure the scraping.
Posted on Feb 14, 2009
Ive changed the belt on my white knight tumble dryer CL 372 once put back together the drum won't turn and makes a loud noise
There are two do-nut shaped rollers that the tumbler rests on located behind the tumbler. One or both could be bad. Some models have a single "axle" in the center of the tumbler that may be causing the problem.
Oct 10, 2014 | Dryers
How to replace door handle on a White knight tumble?
quicker and easier to replace the door, cheaper in the long run.
Jul 23, 2014 | White Knight Press Genuine Tumble Dryer...
White knight gas tumble dryer
On most clothes dryers, whether gas or electric, the drum is rotated by a belt, which runs off a motor. The most common reason for it not to tumble is that the belt has broken.Someone needs to replace that belt. If, however, when you start it up , you do not hear a humming sound whilst pressing your ear to the top of the machine, the motor itself may not be turning, which could also be the problem. Be blessed.
Dec 15, 2013 | Washing Machines
I can get the back of my white knight 38AW tumble dryer
try lifting the top of the dryer it usually pops up in the front then you will see the drum and the belt
Sep 27, 2012 | Abbaka White Knight 38AW Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
How do i fit a new belt to my white knight cl447 wv dryer
Pop the top (spring clips) remove the front - use care with the wires. Find the belt tensioner on the floor of the dryer. Do a complete cleaning of the inside. Put the new belt around the drum get an assistant to help you hold the drum while you thread the belt through the tensioner and place the tensioner in the tensioner holder slots sin the floor. Put the front back on, snap the top back down.
Allow 2 hours for this job.
Feb 17, 2010 | Dryers
Cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
May 01, 2009 | Dryers
How to fit new drive belt to white knight tumble dryer
YOU HAVE TO REMOVE BACK AND EASE REARWARD - THEN SLIP DRUM BELT IN FRONT OF DRUM THEN REASSEMBLE - NOT EASY TO EXPLAIN
Apr 05, 2009 | Dryers
Dryers Logo
74 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
