Question about Soundstream Amp Rub5.800 5 Channel Speaker Sq Amplifier
I have a Soundstream Rub5.800 amp for about 2 years and that last week started tripping the protection circuitry on the amp. I have read that it could be a short circuit but I don't know where because it just started all of the sudden after starting up the car. I checked the ground wire and redid the ground and also have replaced all of the fuses on the amp and the main fuse on the power wire. When it happens I know that amp is not hot because most of the time its right after I start the car. I have had the car battery and the alternator checked and are both in great working orders. So I don't know what the problem is
  • 631 Answers
SOURCE: soundstream ribcom500
You can get the schematic from SoundStream. If you get the schematic and need help, email it to me at:
babin_perry@yahoo.com
If the amplifier does nothing, post the DC voltage on each of the pins of the SG3525 (or whatever IC they're using in the supply). Use this as a template:
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Posted on Nov 09, 2007
SOURCE: amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Posted on Jan 02, 2008
  • 4 Answers
SOURCE: soundstream amp blows fuses
try to disconect the speakers and turn the amp on and tell if it still blows the fuse
Posted on Dec 28, 2008
WaNg BaNg
  • 16 Answers
SOURCE: no power going to the amp but power running
there is a good possibility you may have a bad ground on the amp but if that does not work just let me know my email is sandman379@yahoo.com
Posted on Dec 08, 2009
  • 12 Answers
SOURCE: i have 2 Soundstream SPL 10 Car Speaker
need to know model number on amp, and the impedance of the woofers
Posted on Oct 19, 2012
I have 2 Soundstream SPL 10 Car Speaker
Apr 06, 2012 | Soundstream SPL 10 Car Speaker
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
PV 500 / Breaker trips during use
Breakers (or fuses) tripping during use can be caused by 2 main causes and one minor one.
1. If there's a short in the wiring between the amp and speaker (or the speaker is shorted internally) the amp attempts to deliver more current than it can tripping the breaker. This may not be a full, direct short but results in a load that the amp can't handle long term. Likely the sound is also distorted to some extent.
2. If the output stage of the amp has some weak or soon to fail components (usually output transistors) that will also lead to high current and breaker tripping. This one requires amp repair - probably by a professional.
The more unusual cause would be protection circuitry issues but I'd check the other 2 first.
Oct 26, 2010 | Peavey Audio Players & Recorders
Sound stream little wonder 62o. keeps tripping off for no reason its new only 3 weeks.spoken with other persons they have the same problem
IN MY OPINION I WOULDNT OWN A SOUNDSTREAM AMP NOT BY ANY MEANS KNOCKIN UR AMP BUT IVE NO GOOD LUCK W ANY SOUNDSTREAM AMP IVE EVER HAD
Feb 19, 2010 | Soundstream Tarantula Car Audio Amplifier
Sub keeps loosin bass
Its probably not your subwoofer- its likely that your amp is showing its age after 2 years of bumping -But it could be that you have partially roasted the coil on the sub which is tripping your amp into protect mode-thus shutting down throw a different sub in there for a week and listen to it and if it stops acting up then its probably the sub if it still shuts down then it may be time for a new amp
May 29, 2009 | Fusion FEW12PK Car Subwoofer
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Sounstream tra 560.2 always in 'protect'
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 01, 2008 | Soundstream Tarantula Car Audio Amplifier
Soundstream ribcom500
Contact www.resolutionelectronics.com.au
they should be able to help and have all the spare parts.
Nov 07, 2007 | Soundstream VGA400.2 Car Audio Amplifier
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Nov 07, 2007 | Soundstream Davinici Car Audio Amplifier
Amp staying in protection mode
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
Soundstream Amp Rub5.800 5 Channel Speaker Sq Amplifier Logo
51 people viewed this question
Top Soundstream Car Audio & Video Experts
Jerry Umali
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
