Transformer in buffalo hd-lbu2 external hard drive working but no power in the unit
    Problem Solver:
  • 5 Answers
Well that is a pickle. If there is no warranty left on it you can allways try to open it up a bit and check with a geiger if the juice is running through it.By Geiger i mean a voltmeter
.http://www.youtube.com/watch?v=T1BT5kw6sqY that should help a bit and if the connections are good you might wanna get yourself one of theese
http://www.amazon.co.uk/Buffalo-HD-LBU2-External-replacement-adaptor/dp/B007FI1PH2
Posted on Oct 20, 2013
lock123
  • 6831 Answers
SOURCE: System freezes when I connect my external hard drive.
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
  • 10406 Answers
SOURCE: Everything worked fine until yesterday
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
Testimonial: "THanks - I'll give it a go!"
SOURCE: My Buffalo HD-PX320U2 External Hard
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Posted on Dec 11, 2010
  • 130 Answers
SOURCE: my buffalo external hard disk
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Posted on Apr 13, 2011
bronk50
  • 27725 Answers
SOURCE: Hi i have a HD-LBU2
first we will deal with the error CRC because there are many CRC errors im not sure which yours relates to
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
in left panel extend the events there you will see errors in red right panel you will no what exactly what the error was and at what time it occured if its a system file error
click start run type cmd then type chkdsk/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen when you restart your computer another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in the box to repair the attempt a repair on the files then select check now,start should schedule this task when restart you any input while the chkdsk utility is in progress it might damage your hard drive
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Posted on Sep 17, 2011
Error code 127
What does the manufacturer's information say a code 127 is? We need to know that to give you any help. What did they try to fix already?
Jul 21, 2014 | Buffalo Jeans Buffalo 1.5TB DriveStation...
External HD isnt recognized by ps3
Hmm, go to Start, Control Panel, Administrative Tools, Disk Management. Then look or scroll down right hand panel to find your disk. If it is there you could RIGHT click on it and assign a new drive letter such as Q or R.
If it's not there your external disk could be faulty, the power supply transformer or power cable could be faulty or it could be the USB cable.
If all looks OK you probably need to contact a disk recovery specialist such as DATA365.
Comment: NTFS is a much more stable file system and is much easier to recover after errors. FAT32 is not commonly used now.
Dec 08, 2013 | Buffalo Technology Computers & Internet
Buffalo HD-LBU2 not reconised by computer
Try a drive dock on the Removed Hard drive. The usual problem is the enclosure.
Apr 12, 2013 | Buffalo Technology DriveStation HD-HC500U2...
Buffalo external 1tb won't power up
Return the hard drive to the place of purchase, this is a manufacture defect.
May 12, 2012 | Buffalo Technology Buffalo DriveStation...
Have a 1 tb buffalo external hd. worked great had it for back up. I unplugged it to move my computer. when I plugged it back in, there was no green light no power to the drive. check voltage and the power...
try to test it on other computer or laptop... if the unit are still exist maybe your problem would be the external drive..there are no switch button on it, because most of the switches are located on the adapter, the only testing you could do is to test it to other unit..If the external drive are ok once after you test from other PC's, then might as well check your USB port by plugging-in to other port...or try to use other power supply on your computer, co'z sometimes the supply can no longer supplied any voltage coming from your external drive once it plug-in..
Aug 20, 2011 | Buffalo Technology DriveStation Axis 1 TB...
External Buffalo Hard Disk 500 Gb model no HD-PF500U2/BK-AP not detecting when connnected to a laptop or a desktop PC
Check the usb port function in the computer bios settings and be sure that it is set to yes. Connect properly your external drive. If it has two wire usb connections, use both to obtain the maximum power that will be need by your drive.
Dec 18, 2009 | Buffalo Technology 500GB DRIVESTATION...
Plug in 220 v power line, it burns and smokes. Can data be saved?
Is the power supply internal or external? If external, then just find a similiar or identical unit. If internal, then you could try removing the hard drive and installing it temporarily in a desktop system. Obviously, interfaces must match (SATA, IDE). You could then see if it is accessible, and get any files.
Aug 18, 2008 | Buffalo Technology DriveStation HD-HC500U2...
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
