Question about Viking Ovens
Viking Professional Burners turn on if you open the oven door. You can then close oven door and burners remain on; however, oven does not turn on at all. Suggestions? Thanks
  • Viking Master
  • 5,323 Answers
1.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
2.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
3.
4.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Posted on May 11, 2015
SolutionGuy
  • 331 Answers
SOURCE: Oven burners won't shut off
Bat, your model number is right on accurate. Here's the scoop... the F3-E2 means the temp sensor inside the oven cavity needs replacing, but I doubt that your problem is the sensor. The problem is your "microcomputer". I call it an ERC for short. There are 3 separate circuits on your ERC; low voltage for your keypad, medium voltage for the mechanical relays and high voltage for you elements. When you program a cook time/temperature, the ERC translates this into medium voltage and activates the proper relay on the ERC (i.e... "bake", "bake w/ convection", etc...) to send high voltage to the proper component. All of that to say this, the relay on the board that activates the bake element is "welded" shut. When powered off, the relay won't open up! This will result in run-away temps. I've seen this before on Whirlpools. The ERC will have to be replaced, the part number is #8302994 and lists for ~$180.00 at your local appliance parts store. If you need assistance with the replacement procedure, post back. If you decide to get in there without posting back, DISCONNECT POWER AT THE BREAKER PRIOR TO ANY SERVICE.
Posted on Aug 15, 2007
shivam4529
  • 150 Answers
SOURCE: Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Posted on Nov 23, 2007
SOURCE: cleaning our viking oven
I had to clean mine the old fashioned way -oven cleaner and elbow grease. Fortunately the oven comes apart in ways I never imagined so I could remove, for instance, the sides and bottom and clean them without bending over with my head in the oven!
Posted on Dec 22, 2007
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
Posted on Nov 18, 2008
  • 306 Answers
SOURCE: How to light Oven Pilot for Magic Chef stove 31000 PAW
There is a cover plate that has two screws holding it down. Inspect the pilot area and you will see a hot surface igniter sitting right next to it.. That is what lights pilot and then the pilot lights main burner. You need a new igniter. Also do not touch any part of the hot surface igniter as human oil will shorten the life of part.
Posted on Nov 26, 2008
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
Apr 22, 2011 | Viking 27" Professional Select Built-in...
I just had my 30"
Hello michelle. go to this viking link for the free downloads
http://www.vikingrange.com/consumer/library/documentation.jsp?id=cat40032
Joe
Thanks for choosing Fixya!
Mar 12, 2011 | Viking Ovens
I have a Viking gas single oven with four burners. The burners work fine but the oven won't fire up. I smell gass an I see a glow under the oven but no heat. But if I turn it to broil I get some heat but...
I had the same problem with the single oven, It the voltage feeding the oven, it like to be 120 or above if it drops below 120 then this problem occurs. I had ever thing checked, gas pressure, and the oven. Electrician installed a voltage regulator on that circuit.
Dec 30, 2010 | Viking Ovens
Oven will not light.
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 04, 2010 | Viking 27" Professional Select Built-in...
How long to run self clean on viking professional
The "Self Clean" will run for quite a while up to 4 hours I believe, during this time, the stove heats up to about 900 degrees!! and during this time the Door is automatically closed via special locks. It will allow you to open once it is finished, it should "Signal" this event.
Feb 11, 2010 | Viking 27" Professional Select Built-in...
Viking professional gas range isn't heating properly
The ignitor must glow brightly, if it is dim it is probably too weak to open the bi-metal safety valve. Take a LOOK
Jul 17, 2009 | Ovens
Top burners on our Viking work fine, however the
Hi, There is a good chance the ignitor is bad. Even if it glows, it could be weak enough that it will not open the gas valve. It is very a common problem with the gas stoves.
I would change the ignitor.
Vic
Jun 27, 2009 | Ovens
No power to clock or oven with the door closed
it sounds like the oven lost its neutral feed. I would check where the cord goes on for a good connection at the middle terminal(white) if not there it may be lost elsewhere Dont forget to rate my solution as solved if i answered you question accurately....Thanks!!!
Sep 30, 2007 | Whirlpool RBS245PDS Electric Single Oven
Aug 14, 2007 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
143 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
