Question about Sewing Machines
My serger is sluggish to sew. The knob on side of it is hard to turn. What could be the problem?
  • 68 Answers
It needs to be serviced. Cleaned and oiled.
Posted on Oct 20, 2013
  • MissFixIt828 Oct 20, 2013
How do I fix a serger that sews backwards?
move the sewing direction knob /lever to forward
Sep 27, 2016 | Sewing Machines
My serger is leaving marks on the fabric...little lines like from the feed dogs. I have cleaned, checked everything and cleaned again. I've also tried several different fabrics.
This sounds like too much presser foot pressure.
You can reduce the pressure on the foot by turning the knob on top of your serger counter clock wise
Apr 08, 2015 | Sewing Machines
Babylock bl5260
it would be a good idea to have the serger checked
Nov 15, 2013 | Sewing Machines
I have a Singer serger pro4d that the wheel on the side is hard to move and when it sews its sluggish. What is wrong with it?
It is SEIZED!! Take it in for service. Sergers should be seviced annually as they are notorious for seizing. It's an easy fix and your machine will be unrecognizeable upon it's return
Machine Tech
Oct 20, 2013 | Singer Tiny Serger TS380
Serger repair
it's possible that there could be a loose or broken part in the serger, it would be a good idea to have the serger checked.
Aug 19, 2013 | Juki Sewing Machines
Baby lock serger motor slows down after sewing 20 minutes. Why?
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 22, 2012 | Baby Lock Eclipse Serger
Related Tags: slow sewing stops lock not sewing Print Email Flag Problem with Baby Lock Eclipse Serger I have a Baby Lock Serger BL-90. When it has been on for a while and I'm sewing, it starts t
Perhaps was same as my problem.
Call your local service shop. Baby Locks in closets for years often have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Jul 02, 2012 | Baby Lock Eclipse Serger
Just took my new serger out of the box, the wheel will NOT turn, no matter how hard I try it is stuck. How do I get it to turn??? I tried to loosen the screw, that didn't help. Yes I am NEW to sergers but...
Contact Brother. If this is a brand new Serger, it's under warranty. And they may have some info that will help!! Check your book there's a telephone number in there.
Feb 06, 2011 | Brother 1034D Mechanical Sewing Machine
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
Threading elna lock pro 4 DE green knob
My lower looper thread keep breaking, what is the problem.
Feb 17, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
