Question about Maytag Legacy Top Load Washer
My maytag legacy washing machine is making a loud noise while the water is being pumped out...any ideas of what the problem could be?
vest6
  • 196 Answers
SOURCE: Maytag Netune Mah4000AWW
Makes a loud humming noise. Does the machine go thru its cycles ? Is the humm ther all the time ?
Posted on Jan 15, 2008
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
Posted on Jan 13, 2009
SOURCE: maytag pavt234aww
I had to replace the pump assembly, the pulley has a bushing in it that was working its way out and rubbing against the base plate of the machine.
Posted on Feb 14, 2009
  • 51 Answers
SOURCE: My Maytag HAV2557AWW Loud Noise
pull hoses off the pump and see if there is anything stuck in it
Posted on Jun 14, 2009
milten1
  • 1304 Answers
SOURCE: my maytag wash machine mavt446aww is make a loud noise
your center hub is going
Posted on Oct 05, 2009
I replaced the brake, brake stator, and snubber ring on a Maytag MAV7650AWW top load washer. Now, when it is running it makes a loud grinding or humming noise. Nothing appears to be leaking. I ran it with...
most likely a bad water pump/remove belt and turn pump by hand , you'll be able to tell if its the pump by the way it turns,should turn smoothly in both directions
Mar 06, 2010 | Maytag Atlantis MAV7551 Top Load Washer
My maytag washing machines makes a loud ticking noise while it spinning what could this be?
it could be the tne belt is already damage and the pump motor Need to replace the pump motor and belt
Oct 12, 2009 | Maytag Legacy MAV208DAWW Top Load Washer
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Jun 12, 2009 | Maytag HAV2557 Top Load Washer
Spin cycle not working, was making loud noises,water won't drain
i dont have a model number ..just tip unit prop it up try and spin unit with belt on with your hand ,,than take belt off and spin pump pully..by itself...onthejob
Jan 24, 2009 | Maytag Performa PAV2200
Jan 12, 2009 | Maytag Legacy Top Load Washer
Loud whining sound during the spin cycle? Any ideas
Its possible, something is in the water pump making that noise, if not then its either the gearcase, basket drive/clutch.
Nov 16, 2008 | Maytag MAV9600 Top Load Washer
Jan 06, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Nov 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
