Question about Furniture
Cozzia ec618 backrest is not working anymore... Wont scan back and i dont think it is getting power. Have it plugged in and not getting anything.
5 Suggested Answers
TampaNative
  • 778 Answers
SOURCE: Pro Scan doesn't power up
Pro Scan/RCA TV's (Pro Scan's are just glorified RCA's TV's) don't hold up very well (cheap components). You can try removing the back and checking the fuse/fuses (could be that simple), but if it's over 5 years old? You may be looking for a new TV soon.
You should find a fuse on the circuit board near where the power cord goes into the back.
I hope this helps, and Good Luck.
Posted on Mar 04, 2008
tripletauto
  • 1450 Answers
SOURCE: Power plugs
have you checked your fuses?
Posted on Aug 21, 2008
  • 4 Answers
SOURCE: When I try to scan, I get error message on printer
I think you have installed the HP full feature software in the computer.
You can check it, you need to click on Start button -> All Programs -> HP -> HP Director
please check if you are able to scan from HP Director (if yes then change the below settings so that you would be able to scan from the button on the unit)
open the HP Director -> click on "settings" -> scan settings -> scan to setup and you need to populate all the options which you see in the left panel. when you will populate all the options to right panel. Then click UPdate device or OK button. and then try to scan again from the button on the unit. It will work. If it does not then check for the DIM (Digital imaging monitor) icon in the system tray, it would have a green checkmark over it. if you do not see it then you have to start it from the below steps
please click on Start button -> My Computer -> C: Drive -> Program files -> HP -> Digital Imaging -> Bin -> hpqtra08.exe when you will double click on the file, you will see DIM icon in the system tray and you will be able to scan from the button on the unit.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01798218&cc=us&lc=en&dlc=en
you can also click on the above link to understand it better.
I hope it will definitely help you out.
Posted on Dec 11, 2009
sulavaca
  • 1007 Answers
SOURCE: 2005 Galant driver's power seat will move forward, but not back. The backrest does the same thing. I think it's dirty / worn switch contacts, but a shop says the motors are bad and need to rep
Pull off switch panel and with multimeter, check switch operation.
If faulty, then check motor operation.
Posted on Nov 14, 2012
I have a 2001 Chevy Tahoe. When I try to fold the
One of the cables that control the release is broken right where it hooks to the seat,, the cable has a loop made in from factory it wears threw there,,, this is just one of the causes but the most common,,, also could be bottle cap or small piece of something making it hang up,, hope this helps
Oct 10, 2014 | 2001 Chevrolet Tahoe
Engine idles up while riding and check engine light comes on. When I let out the clutch and put a load on it, the light will go out and the idle will bog down while putting a load on the engine.
would really help if we actually knew what kind of vehicle it was, did you add anything onto it or make modifications ???
because i dont think a heated seat with backrest is the problem UNLESS you wired it up yourself
Dec 29, 2013 | Saddlemen Heated Explorer Seat With...
I was using my dell latitude d510 just fine the other day the only thing that was wrong is the battery wont charge so it always had to be plugged in. well from using the charger so much it finally stop...
The problem could be with the port the cord connects too. It could also be with the battery. If you take the battery out, and you still can't run on AC power, you need to replace the port. Take it to a computer/hardware shop and have it done.
Feb 24, 2011 | Dell Latitude D510 Notebook
TURNING OVER BUT WONT START REPLACED COIL PACK, FUELPUMP, FUEL FILTER, PLUGS AND WIRES. CANT FIGURE OUT THE PROBLEM
Have you checked the injector wiring? Each has only 2 wires you can check. If no power, test the injector power control module.
Sep 09, 2010 | 1995 Eagle Talon
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Jun 11, 2009 | 2005 Ford Escape
Power plugs
Aug 21, 2008 | 2003 Nissan Xterra
Mar 04, 2008 | Proscan PS35660 TV
Furniture Logo
172 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
