Question about Vacuums
These are all new, nothing is stuck on them anywhere, no clogging, no hair, no gunk, no nothing.
    Sergeant:
    Champion:
  • Vacuums Expert
  • 357 Answers
Was there supposed to be a question here ?
Posted on Oct 21, 2013
Testimonial: "I don't know how my post got on the vacuum page, my problem deals with Danze touchdown drain stoppers."
What does a flashing light on the dc28 vaccuum mean
There are a few things a flashing light could mean. One is that the beater bar has something stuck on it. Or, it could be that the bag or canister is full. Then again, maybe something is stuck in one of the intakes. Be careful when checking the beater bars. Unplug the vacuum before touching them, you wouldn't want your hands getting injured or fingers broken:( Clear anything that is wrapped around the beater bars, hair, string, etc., and then check the hoses to make sure nothing is stuck in them. If you have suction, the interior is clear. If not, then check in there to make sure nothing is clogging it. Good luck and be careful:)
Jul 23, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
I have a number, 132020-000023, that is supposed to refer to my last explanation. Apparently you were unable to see it. I have 4 Danze South Seas faucets with touchdown stoppers that can be pushed down...
Sorry Kitty, but you've wound up in the Vacuum repair category for some reason. Probably should go back to the beginning and start over.
Oct 21, 2013 | Vacuums
While vacuuming it gets hot and shuts down
It's probably just overheating. You have to take the vacuum apart and clean it thoroughly. There is probably a "plug" of dirt/hair/gunk clogging a hose.
I have had cheap vacuums that last years as long as I clean them regularly.
Feb 12, 2013 | Vacuums
Carpet function won't work.
You are going to have to get a screw driver and remove the bottom plate and the hoses. You are correct, there is a clog. You might be able to clear if you have a shop vac. Be prepared to remove all the connections in the dirt path to remove the hair ball.
Thanks for your interest in FixYa.com
Feb 20, 2010 | Vacuums
Stuck Roller
Befrore you plunk your $ down ...
I dont now that you melted the hair so much as you may have an accululation of gunk and hair. If there is a good (not 'fast food' type) auto parts store near you, go there and ask the counterman for his or her recommendation for cleaning those surfaces. I have had success with OOops and other stuff in that same area.
I hope this helps you
a
Sep 23, 2009 | Electrolux 1910 Bagless Upright Vacuum
Bissell 2x wont **** up the dirty water
take the tank off and turn the unit on and see of there is section where the tank would sit. If so then the tank is not seated correctly, if not it is plugged with something.
Jun 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction
you still have a clog in there something is keeping the brushes from spinning. Be sure to remove any hair/string etc twisted around the brushes. Make sure the belt hasn't slipped off the metal pin behind the brushes, this is what creates the rotation. The brushes have a hard plastic molding on each end that fit into the sides of the vacuum. Make sure you have these on the right way or they will strip out and you have to replace the housing and the brushes. Have you cleared any blockages from the feed behind the brushes? Be sure to take the hose and extend it out and run a broom handle or something down it to be sure you do not have something lodged in there. Good luck .. if you need more detail post back. These can be rebuilt if needed, hopefully it is just something lodged further down the suction canal.
Nov 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
I am wondering how I can clean the inside of my bissell spotlifter powerbrush hand held cleaner? I want to clean the part where you suction up - it is full of gunk and hair and I can't figure out if it...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=49876&thid=506980
Posted by carriespets on Apr 12, 2008
I am wondering how I can clean the inside of my Bissell Spotlifter Powerbrush hand held cleaner. I want to clean the part where you suction up - it is full of gunk and hair and I can't figure out if it comes apart or not so I can clean it. Can you help?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Normally on the Bissell Spotlifter Powerbrush the item will comes apart from the sides into 2 halves and then you can either clean out or blow out the inside of the
Bissell Spotlifter Powerbrush, also you can take a wire coat hanger and straighten it out and bend a hook @ the end of the wire hanger and you can use the hook to pull out the clog or whatever is blocking the opening and you can also use a blower or an old tooth brush to clean the motor or to brush it off.
Always, check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 12, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Vacuums Logo
15 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
