Question about Garden
Stihl farm boss
How would i convert the piston displacement from 61cm to english measurement?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Why would you want to ??? and it's mm not centimeters
61cm = 24 inches
61mm = 2.4 inches
Posted on Oct 20, 2013
  • 302 Answers
SOURCE: What is the carb setting for a Stihl 41 farm boss
Start with both the H and L jets out 1 1/2 turns and fine tune it from there. hope this helps you.
Posted on Oct 06, 2009
nedkelly900
  • 345 Answers
SOURCE: how do I find Stihl 041 s/n with silver sticker gone?
you cant. that is the only serial number on the machine
Posted on Apr 28, 2010
puertobori
  • 7733 Answers
SOURCE: I have a ms 290 farm boss with an 18" want to
Yes! So here are some links:
STIHL Ematic guide bars are engineered and manufactured to STIHL's strict quality control standards and are produced in STlHL's own factories. STIHL offers a full line of guide bars for all types of use from 10" for specialized wood carving applications with small saws through 59" for extreme felling operations. Explore our products to find the STIHL guide bar that's right for you. Locate your local STIHL dealer.
arrow_orange.gif STIHL ROLLOMATIC® ES Super arrow_orange.gif STIHL ROLLOMATIC® E Light
arrow_orange.gif STIHL ROLLOMATIC® E Standard arrow_orange.gif STIHL ROLLOMATIC® Mini
arrow_orange.gif STIHL DUROMATIC® E arrow_orange.gif Carving Guide Bar
Thumbs back!
Posted on Nov 07, 2010
snowghost1
  • 784 Answers
SOURCE: I have a Stihl .029
I have owned and use Stihl saws for the past 18 years and I have seen both these problems many times. as for the chain 'getting tight' -- when you go to adjust the chain, make sure you are lifting up on the tip of the bar as you set the tightness -- you should be able to only pull the chain away from the bar about 1/8th of a inch. now, while tightening the bar bolts make sure you still are pulling up on the tip of the bar,, and make sure the bar bolts are nice and tight -- not to tight though, the bolts that Stihl uses are a very weak point on their saws and I have broke more than just one. but make sure after one is tight that you tighten the other one and then give the first nut one more 'little' nudge tighter. new chains do have a break in period and they have been known to tighten up and loosen as they are running,, just keep your eye on it for awhile and thighten or loosen as needed.
now I am kinda confused on your next problem -- you say ' winter mix bar oil ' -- using this oil should not have anything to do with it stalling out, ( enless you are mixing bar oil with your gas ?? ),, make sure you are using Stihl 2-stroke oil to mix with your gas at a ratio of 50:1,, ( you can buy small bottles that mix with 1 gallon or a bottle that will mix with 5 gallons -- use 'em ). one thing that I have had troubles with when my saw wants to stall out is the fuel filter inside the fuel tank in the wrong position and is sucking air. also I have had fuel lines that crack and/or split and they **** air.
now the winter bar oil -- please,, I have been running Stihl saws in temperatures ranging from minus -5 to 100 degrees above and I have always used the SAME bar oil year round and had NO problems. on the side of the saw there is a bar oil delivery speed screw and you can adjust it to flow more or less -- your manual should show you the exact location of this screw,, make sure you clean out any debris that might be blocking the weep hole for the oil delivery. you need to make this adjustment with the bar and chain off the saw and you will see the flow of the oil and you can adjust to a good flow.
I am a firm believer in buying and using Sthil chainsaws,, I will never buy anything else,, they are great and out last any other saw I have used or seen,, and your Farm Boss is a great saw and should give you many years of trouble free use.
one suggestion that I would make real quick is to ' change your saw mechanic ' -- find one that has been ' WORKING ' on chainsaws ( not just selling them ) for along time,, someone that has your interest at heart and is there to help you,, not just to take your money.
(((( I am still laughing at the ' Stihl Winter Mix bar oil :-) )))).
good luck with your saw,, and if you have anymore questions about this please feel free to write me back here and I will do my best to walk you through what it is that you need to know and do. again - I have been using and working on chainsaws for most of my life.
have a great night,
c...
Posted on Feb 10, 2011
  • 95 Answers
SOURCE: My Stihl Farm Boss 029 leaks gas when I run it.
It could be the fuel tank vent is missing.try looking up your model number at ereplacementparts.com.It will show a diagram of whats where and the part you might need.
Posted on Mar 07, 2011
Farm boss starts runs great until hot then stops dead let it cool and it runs what do I try?
Most likely needs to be torn apart, the cooling fins on the engine need to be cleaned regularly, also you have carbon build up inside muffler, there is a screen inside muffler, if not clean, you will eventually get a scored piston and cylinder wall, then you will need much more to fix the issue, also make sure you are using the correct ngk plug
Sep 27, 2017 | Stihl Farm Boss Chainsaw 18"
How do I find a parts manual for a Stihl MS290 ?
You Google pretty much exactly what you wrote and you get this
[PDF]STIHL Chainsaw Illustrated Parts Lists n Workshop Service Manuals thebakeliteradio.com/sawspares.com/Stihl%20MS310%20Service%20Manual.pdf
  1. Cached
  2. Similar
MS 290, MS 310, MS 390. This service manual contains detailed descriptions of all the typical repair and servicing procedures for this power tool. As the design ...
[PDF]STIHL MS 290, 310, 390
en.stihl.ca/p/media/download/en-ca/MS_290.pdf
  1. Similar
Apr 19, 2006 - MS 290, MS 310, MS 390. English. BA_. SE .... Manual. !Warning! Because a chainsaw is a high-speed .... and the function of the parts of your.
Stihl MS 290 STIHL FARM BOSS ' Parts List - ManualOwl.com
https://www.manualowl.com/m/Stihl/MS-290-STIHL-FARM-BOSS/Manual/401004
  1. Cached
  2. Similar
Stihl MS 290 STIHL FARM BOSS ' Parts List - Page 1. STIHL MS 290, 310, 390 A Zylinder MS 290 Cylinder MS 290 Cylindre MS 290 Zylinder MS 310 Cylinder ...
Stihl MS290 Parts List and Diagram : eReplacementParts.com
www.ereplacementparts.com/stihl-ms290-chainsaw-parts-c-162329_162330_182548....
  1. Cached
  2. Similar
Need to fix your MS290 Chainsaw? We have parts, diagrams, accessories and repair advice to make your tool repairs easy.
Stihl MS290 Parts
www.barrettsmallengine.com/stihl/ms290.html
  1. Cached
  2. Similar
Find parts in the Stihl MS290 chainsaw parts list below and find where to purchase them online.
Stihl MS290 Repair manual ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
  1. Cached
  2. Similar
Nov 4, 2008 - 20 posts - ‎18 authors Hi, I am new to this site and was looking for some help on rebuilding an MS290. I have the replacement cylinder and piston but need tips on ...
parts manual for Stihl MS290 Google Search
Dec 18, 2016 | Stihl Garden
Any complaints of saw catching fire?
Not really, but if you've had the issue, maybe the vent tube is allowing gas to be dripped into the carbuetor compartment behind the filter. Sometimes, when held horizontally, they will leak a bit out and older saws sometimes have the vent line to deteriorate from the alcohol in todays fuels causing a few drops of gas to escape. I've worn out two 041 Farm Boss saws and never a problem other than normal maintenance.
Mar 15, 2015 | Stihl 041 Av, Farm Boss Chainsaw Intake...
How do i clean oiler for chain on stihl farm boss?
The filter could be stuffed with sawdust, but depending on the model of saw, the problem could also be the oil pump drive system.
First of all though, empty out the chain oil and then part fill the chain oil tank with petrol, replace the cap and with the saw switched off, shake the saw violently for 10 secs. Remove the cap and empty out the tank and then refill with chain oil and try out the saw, revving it and check if any oil is flowing onto the chain.
If that has not solved the problem, let me know what the model of the saw is, Farm Boss is not enough, it could be an 038 an 041 and a few more as the farm boss name is used as well as the number.
We can then check a few other points which could be causing the problem.
Sep 16, 2014 | Stihl Farm Boss Chainsaw 16"
No spark?
remove the side cover remove the small wire from the coil if still no spark replace the coil
Sep 26, 2012 | Stihl Garden
Early 90's stihl 029 farm boss difficult to start and won't start when hot. could this be a piston and rings problem?
It very well could be. Pull the muffler and inspect the piston and cylinder for any scoring.
Jul 11, 2011 | Saws
How do I find Stihl 041 s/n with silver sticker gone?
Apr 16, 2010 | Garden
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
