Maytag A183 and it will randomly fill up with water. We won't use the washer for a day or two and it will have several inches of water in it. We have to turn the spin cycle on to get the water out. It doesn't happen all the time, maybe once every couple of weeks.
  • DanH
    DanH Oct 21, 2013
    Thanks for the response, I'm assuming that the water supply valve is the same thing as the water inlet valve description that I found on a parts diagram? Thanks again.
    Master:
  • 818 Answers
You have a leaking water supply valve that is allowing water into the tub while not running-try unplugging the power when not using and see if it still happens-this would eliminate a problem with the controls messing up-if its still doing it you could shut the water off at the wall between loads and replace the water control valve at your leisure-cheers Denny
Posted on Oct 20, 2013
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
SOURCE: MAH3000AWW
Went through the same routine, first repaired the upper control board R11/Q6 issue and replaced wax motor.
http://members.shaw.ca/gavb/index.html
Worked for a couple year and quit again so I bought a new board, close to $300 I think it made a huge difference I think they changed the programming to spin out better.
Posted on Jan 24, 2008
wpcustomer
  • 362 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    SOURCE: Maytag Centennial washer agitates when
    Don't know what it is , but the 3 guys above me are wrong
    Posted on Oct 16, 2012
    Maytag atlantis washer water won't stop filling with water even when power is off.
    water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
    Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
    Maytag ensignia top load washer will not fill with water at start of the cycle?
    The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
    Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
    My maytag mtw5600tq1 washer won't hold water. Its
    Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
    I hope this helps
    Aug 26, 2011 | Maytag Washing Machines
    I have a Maytag A183 top loading washing machine. It recently starting making a loud buzzing noise when you first pull out the knob to start it. If you turn it off and on a couple of times, the sounds...
    That loud buzzing noise is your water fill valve. First turn off the water valves to the washer and unscrew the hoses and check that the filters are not corroded or clogged. I had a maytag washer that was doing the same thing and finally the lid switch and timer had to be replaced. I would unplug the washer and remove the screws along the upper rear cover behind the timer assembly and check that all connections are secure. Unplug them then plug back in if neccessary. Then put the cover back on plug back in and try it.
    If it still does it you might need the water valve replaced.
    Mar 13, 2011 | Washing Machines
    My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
    Bonnie,
    NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
    Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
    Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
    Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    Maytag washer doesnt fill with water. after about 3 inches of water in bottom, it starts draining out.
    pull the drain hose out of the wall
    it should only be six inches in the wall
    or will create a syphone and the washer will continue to fill and drain and fill and drain
    try this and let me know how it goes
    Feb 09, 2010 | Maytag Legacy Series Top Load Washer
    HE3T Kenmore Frontload Washer Random Draining Problems
    The water pumped goes right back into the machine. It may be because the washer is siphoning the water from the laundry tub with a slow drain and back. Your solutions are advised but try this also:
    1. Check the pump impeller for obstruction.
    2. Cut the drain hose into the laundry tub in excess of 4 inches.
    Aug 21, 2009 | Kenmore Elite 45986 Front Load Washer
    Rinse cycle wont fill
    check your drain hose. needs to be at hieght of tub before entering the drain....should only be 3-4 inches in the drain and secured with a ziptie.
    Jun 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
    Washer won"t fill with water
    check your lid switch if its a top load
    May 18, 2009 | Maytag LSE7806A Top Load Stacked...
    Washing Machines Logo
    32 people viewed this question
    Top Washing Machines Experts
