Question about Danze 1 1/2'' Touch Down Drain DANZE D495080BN
The Danze touchdown stopper can be pushed down and it does not leak. It also will not pop back up no matter what, unless you can thumb-screw it backwards to get the stopper lid off. The rubber gasket seems to hold down and the spring that pushes the stopper up and works with the lid off but when you push it with the lid on, it just stays down. We have been sent at least 3 replacement assemblies for 4 of these in our house and they all do it. Even plumbers have tried to figure it out and are stumped. Please help us, we dare not use any of these stoppers because we can't get them back up.
  • 302 Answers
This happened to mine too. I took it apart ( removed the whole part, then removed the cap ) clicked it a few times, stuck it back in, and it's worked fine ever since.
I'm going to say that it may be either a manufacturer thing, or perhaps there's some sort of build up going on.
Either way, you could try doing what I did, or contact Danze and ask for a refund. Maybe a different brand would be in order?
Posted on Nov 03, 2013
3 Suggested Answers
  • 119 Answers
SOURCE: The finish has worn off of the handle and stopper
you would have to contact the manufacture direct and have them ship the parts to you , that is the only place.
Posted on May 19, 2010
  • 10 Answers
SOURCE: My Danze brass pop-up drain assembly w/lift rod
I always use white silicone - putty always cracks and leaks. Silicone makes a sort of custom rubber gaskit and never leaks. Clean off with paper towels immediately before it skins over
Posted on Dec 22, 2010
How to I keep a freeze-proof hydrant from popping open?
The bottom of the rod has a rubber stopper that fails and can cause this. You must turn off water and remove the upper part of faucet to pull out rod.
Aug 08, 2015 | Cars & Trucks
Belle Foret pop-up drain stopper won't release
The drain should be able to pop up after vigorous pushing down on it. When you get it released, you will find it is clogged with goo. You will have to disassemble the pop-up (remember the order of disassembly) and clean all the moving parts then reassemble it.
Apr 06, 2014 | Belle Foret Bathroom Sink Faucet -...
I have a number, 132020-000023, that is supposed to refer to my last explanation. Apparently you were unable to see it. I have 4 Danze South Seas faucets with touchdown stoppers that can be pushed down...
Sorry Kitty, but you've wound up in the Vacuum repair category for some reason. Probably should go back to the beginning and start over.
Oct 21, 2013 | Vacuums
Touchdown stopper will not pop back up
The spring-loaded stopper mechanism may be clogged with hair, soap, and "gunk". Repair consists of removing the assembly, disassembling it (remembering the disassembly order of parts), cleaning all parts, and reassembling, testing, and reinstallation. Periodic maintenance will keep your stopper operating like new.
Oct 20, 2013 | Danze D495080AC 1 1/2'' Touch Down Drain -...
I can not close my bath tub drain. the plunger is all internal and wont come out either. I tried a coat hanger to push it down. no go.
on most tubs the stopper is made to come out! does the stopper have 2 screws at the stopper lever. if it does just remove these screws and pull the stopper out slowly. when putting in a new one. have the same length as the old one, then slide it back in the drain fairly slow until it goes all the way in. replace screws and try it! good-day!
Aug 05, 2011 | Kohler Bath Drain KOH-K-7104
My Danze brass pop-up drain assembly w/lift rod and overflow leaks on the threads that lead upto the flange. I have tried a small amount of putty to a large amount and still leaks after about 1 week from...
Dec 21, 2010 | Danze 1-1/4 '' Brass Pop-up Drain Assembly...
Sink pop up waste won't close
When you pull out the stopper is it completely intact? there should be a hole at the bottom of the stopper were a rod goes through. That moves on an axis pulling and pushing the stopper up and down as you pull and push the lever. You have to make sure you get the rod in that hole for the pop-up to work. You can google pop up assembly and look for an diagram. good luck
Jun 30, 2010 | KitchenAid Home
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
How do I change my cabin filter in a 2009 honda fit
pull down your glovebox(remove the two rubber stoppers on either side of the glovebox) just push on the inside of the plastic that the rubber stoppers are attached to. the stoppers pop out and the glovebox will swing down. behind the glovebox in teh new opening there is a tray snapped into the blower box... dbf4936.jpg
remove the tray with the old filter. insert the new filter and put the glovebox back.
Feb 28, 2010 | 2009 Honda Fit
Bathroom sink stopper came unhooked and out, not attached anymore
You will need to get under there and unscrew the popup rod located on the back of the drain. pull out the rod, drop the stopper in there and push the rod through the hole in the bottom of the stopper. screw the nut back on.
Mar 15, 2009 | Home
Danze 1 1/2'' Touch Down Drain DANZE D495080BN Logo
669 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
