Question about Euro-Pro 416 Mechanical Sewing Machine
Hi, i have used this 416 successfully in the past but am a very novice sewer. The upper thread is getting caught in the hook race. I have followed the maintenace recs..removed the hook race, cleaned and lubricated, checked the needle position, tried to sew with multiple tensions, but it is still happening..what's wrong & how do I fix it?
  • 68 Answers
Make sure the thread is in the tension disks and also in the take-up lever.
Posted on Oct 20, 2013
2 Suggested Answers
  • 25 Answers
SOURCE: thread caught in hook race
There should be a small screw on the side of your bobbin case adjust it little by little until you get the correct tension.
Posted on Jun 15, 2009
When I start to sew, the thread gets bunched up around the hook race unit
adjust the upper thread tension as this indicates the thread is not pulling the bottom thread up tight
Apr 27, 2015 | Sewing Machines
The race and needle of my Juki 8300N is jammed. There was a thread caught but it's gone as far as I can tell now. The needle won't move even if I turn the wheel by hand - it can just barely jiggle...
douche the hook with oil wait a day and use hand force to get machine to turn. u have thread deep inside hook and its binding the machine. u can spray with wd-40 too but use alot and let it sit.
Oct 08, 2011 | Juki DDL-8300
My problem is between the needle and the bobbin. The tread continues to get caught just below the needle- inside of the machine. The bobbin seems to be lifting up and thread gets caught beneath the needle
Hi. So is this a horizontal hook? Where is the thread getting caught beneath the needle? Maybe on the hook? Check your upper threading to make sure the thread passes through the thread take-up lever. If thread is not through the lever, it wont get pulled up , which can lead to multiple thread loops getting caught on the hook, not pulling off after the rotation.
Apr 15, 2011 | White Sewing 2037 Mechanical Sewing...
My machine keeps jamming, what happens is that the top thread gets caught in the hook how do i solve this
Be sure there are no thread tails hanging from the bobbin when it's inserted into the bobbin case. They can jam the machine and cause the upper thread to break. And note that there's no such thing as a generic bobbin. Always use a bobbin designed for your machine in order to avoid skipped stitches, loose threads, and noise, as well as permanent damage to the bobbin case.
Clean your bobbin case and open the race (what you insert the bobbin into) to clean that out as well as the feed dogs. Excess lint can cause a lot of trouble when you're sewing so cleaning and oiling often can save you frustration and damage. Also use a quality thread that will not add to the lint build up.
Your race might also have a small burr that needs to be gently rubbed off. Do not use sandpaper as that will cause more burrs to form.
Hope this helped.
Jan 20, 2011 | Singer Sewing Machines
I cannot seem to thread the lower loop properly,am getting very frustrated
Have you been able to do it successfully in the past? What is the model number of the sewer in question, is it indeed a 644D? Are you following the procedures in the manual, or maybe you don't have one?
Let me know, just reply here.
Thanks
Tim
Oct 28, 2010 | Janome MyLock 644D
Thread caught in hook race
Jun 06, 2009 | Euro-Pro 9125 Computerized Sewing Machine
My brother PE-400 sewing quit sewing
The "race" on your machine needs adjusting. Remove the bobbin cover, bobbin, & case. What you have left is the race, it moves when you turn the large wheel on the top right of machine. The needle also moves up and down. There is a hook on the race that catches the needle thread. Try moving the race to the line up with the needle. It may take a couple of trys but it should do the trick. Also clean any threads that may be caught on or arround the race. Hope this helps!
Jan 02, 2009 | Brother Disney PE-400D Computerized Sewing...
Machine moves normally but does not sew
Okay, I know that you are an experienced sewer and have probably already checked, this but I had the same exact problem today and cleaning the shuttle race fixed it.
Jul 04, 2008 | Kenmore 15208 Mechanical Sewing Machine
Euro-Pro 416 Mechanical Sewing Machine Logo
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
