My Philips sound bar has stopped working for no apparent reason. I've unplugged and re-plugged. I've tried moving around the plugs. Nothing. The power is on, but "nobody is home." HELP!
SOURCE: need help fixing
I had the same problem a couple years ago with mine. After letting it set for several months, I tried to plug it in again after moving into another house. All of a sudden, it started working again. That was 1 year ago, but just last week...it did it again. I noticed that it does this if it is left on for an extended amount of time (my wife goes to bed at night and leaves it on). I cannot find anything on how to fix it, and no warranty assistance from RCA. I'm purchasing a Sony today, but will hold onto the RCA in case it decides to work again.
Posted on Mar 10, 2007
salt56
  • 373 Answers
SOURCE: won`t turn on
Try leaving it unplugged for longer period of time. Look on the remote for any possible reset function. Try power button without the remote. If any ot these doesn't work there is a power supply module inside that malfunctioned. If under warranty contact where you purchased it. If not under warranty if you can get the module it is a simple plug up procedure.
Posted on Dec 31, 2007
SOURCE: No sound
First I will try the following
1. Go into the Setup Screen (via your remote), there are some audio setting. Change it to see it makes a difference. Make sure it is not muted.
2. change from 2 Channel to 6.1/5.1 channels. At the bottom of the remote, there are a bunch of audio setting, play with it and see if it makes a difference.
Posted on Jan 24, 2008
SOURCE: Canon MP830 power outage while printing
My MP830 did the same thing today. I thought it was toast. However through a Google search I found the following suggestion.
Unplug the MP830 for 20 minutes or more. Plug the MP830 back in and hit the power button.
To might great relief my MP830 powered up and is working just fine.
Posted on Jul 07, 2008
SOURCE: Smartdisk Firelite 80GB-Stopped Working
I had the same problem with my firelite usbflb80-c, and carefully took the case off, 4 screws (one screw under the void if broken warranty sticker) my drive had somehow wiggled it's way out if the connection pins. Figures, with 5 yrs of use, all the traveling and occasional dropping. So I carefully pushed the drive back in place until I couldn't see connection pins any more. I plugged it into my computer before I closed it back up. THANKFULLY an easy fix, but I double checked for breaks or cracks before I closed it up. :o) YAY, I thought I had lost all my files!
Posted on Apr 23, 2009
My Philips sound bar stopped working for no reason.
Does it have power? Have you selected the correct input? Is the cable feeding it plugged in at both ends?
May 12, 2014 | Audio Players & Recorders
Refrigerator stopped working
unplug for 15mins , move your fridge to 3 feet from the wall clean the back and don't put anything in the back and plug back
Mar 10, 2012 | Refrigerators
My Canon Pixma MP990 stopped working. First the wi-fi light went out, and the LCD screen went dead. Then the blue light stopped coming on at all, and all I have when I plug in the printer is the yellow...
It sounds like you have an electronic problem, it is most likely a faulty scanner or logic board. although a faulty print head can take out a logic.check that there is no burning smell or damage evident on the underside of the print head before trying a logic.
the machine will require disassembly and parts replacement.
Aug 16, 2011 | Canon Pixma MP990 InkJet Printer
I put my memory card into the Dynex reader and nothing is happening
Move the reader to a different USB port. If that doesn't work, the reader's probably given it up. I've seen several of this brand reader die an early death, for no apparent reason.
Jun 16, 2011 | Computers & Internet
My laptop makes a loud annoying beep when its plugged in or unplugged. The cord is getting tired and often makes this noise for no apparent reason. I've tried to go into the speaker properties but...
this issue might be occurred due to weak battery or either battery is getting weak.Just remove the Battery for a while and check the result
Jun 13, 2011 | Computers & Internet
I ve got a sharp aqueos tv i turned oevr channels
Try this: unplug the power cord from the wall, let TV set stand for AT LEAST 30 minutes, then plug back in and and see if the TV operates as normal.
Sometimes this works and sometimes it doesn't.
Good luck !
Jan 09, 2010 | Sharp 25N-M100 25" TV
Philips LCD TV Matchline series keeps switching off!
heating up issue, try unplugging it and if you can clean the dust from within the unit. Try reversing the vacuum and blowing excess dust out.
Sep 09, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Feb 26, 2009 | Marantz SR7500
70 people viewed this question
 Grubhead
Grubhead
