Question about Sharp Computers & Internet
How to configure SCU problem in sharp laptop - Sharp Computers & Internet
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 225 Answers
Please contact the sharp service center
Posted on Oct 21, 2013
What causes error code E7-14 on a Sharp MX-M363N?
Haven't come across that one before:
Trouble content
Detail SCU
Cause SCU PWB trouble.
Check & Remedy Check the SCU PWB.
Replace the SCU PWB.
You could try resetting the machine:
START (Copy mode)
Press the Program key.
Press the asterisk (*) key.
Press the clear key.
enter 14, execute
Cheers
Andy
Jan 20, 2017 | Sharp Mx-M363n Copier, Printer & Scanner...
What is the full meaning of ptc, mfp, scu, pwb,LSU,LCC,SRAM,SUM,CPT
LSU - Print Head which houses the (LASER)
LCC - Large Capacity Cabinet (Holds a Lot of Paper, more than a normal tray)
SRAM - Static Random-Access Memory
CPT - Toner Cartridge Code
PTC - Primary Transfer Belt Cleaning Unit
MFP - Multi- Function Printer Control Board
SCU - Scanner Unit
PWB - Printed Wire Board (Circuit Board)
Hope that helps
Oct 16, 2015 | SHARP MX-3100N
What is the error code e7-80 on a Sharp ar-m450u ?
E7-80 MFP-SCU PWB communication error
Cause
SCU PWB connector connection trouble.
SCU PWB - MFP PWB connection trouble.
SCU PWB mother board connection trouble.
SCU PWB trouble.
MFP PWB trouble.
Mother board trouble.
Check & Remedy
Check connection of the SCU PWB, the MFP PWB,
and the mother board.
Check the ground.
Replace the MFP PWB.
Replace the mother board.
Mar 10, 2015 | Sharp Office Equipment & Supplies
How to configure beetel m60 one touch memory
Open the memory cover on the laptop and remove the old memory. Then insert your new memory. It configures itself, by the way.
Feb 13, 2014 | Sharp Computers & Internet
SCU problem
explain the problem in detail with full sysetm configuratiion
Oct 20, 2013 | Sharp Computers & Internet
I cannot change the boot order b'coz it asked for scu password. Please, i need your help. thanks alot.
You need to clear the password in the BIOS.You either have to open it to do that from onboard, or you may need a BIOS re-setter software for that
Dec 05, 2010 | Computers & Internet
I HAVE A LAPTOP THAT DOESNT TURN OFF ON ITS OWN? ITS A DELL INSPIRON 630.. I RECENTLY BOUGHT IT (USED) AND WHEN I CLICK TO TURN OFF, IT DOESNT... ALSO, IVE NOTICED THAT IT DOESNT TAKE/READ CDS?? WHAT COULD...
Hi There, the issue you are experiencing can be on account of both software and hardware malfunction. Proper and systematic shut down is a prerequisite for a smart functioning of any laptop. Failing to achieve a systematic turnoff can cause serious issues in future and it is advisable to backup your data. This hazard usually has its root in the software part of the system. But seldom it also arises due to hardware malfunctioning. Let us have an insight into some of the main causes of your problem what you can do to resolve them:
1. Just find out whether you opted for a Fast Shut Down feature of the Windows as this complication mainly occur by activating this mode. To deactivate fast shutdown mode, just click on the Tools from accessories menu and there you will find System Configuration Utility (SCU). You can disable the fast shut down mode from SCU. Henceforth you can restart your laptop again.
2. This problem may also arise due to extremely slow speed of your system. Please make sure that your system is operating on an optimum speed to support the various operations of your laptop. You can use the system utilities to free up disk space and clean up temporary folder.
3. You might have installed a corrupted or damaged file which is adversely affecting the operation of the system on a whole. So thoroughly scan your system to eradicate such files from it. Also try starting up the system in Safe Mode and then try to turn it off. If you are able to turn off the system in safe mode then the issue lies with software that you may have installed. Try uninstalling any recently installed software or device driver that may be causing this issue.
4. If all of the above steps fail to resolve the issue, please perform a System Restore to a date when your Laptop used to shutdown properly.
5. If the problem continues to occur even after applying the above methods then your laptop might be in a grip of some hardware complication which is hard to identify from here. In this case it is prudent get your laptop checked by efficient engineers
Jun 01, 2010 | Lenovo ThinkPad R500 Notebook
Laptops don't have static IP. I want to change the configuration
I think the generic username is Administrator and the password is either "admin" or "Sharp"
Aug 12, 2009 | Sharp AR-M207E Black and White Copier
Computers & Internet Logo
29 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
