Question about Fishman Loudbox Performer Amplifier LBX 300
Fishman Loudbox Performer Amplifier LBX 300 - Fishman Loudbox Performer Amplifier LBX 300
4 Suggested Answers
  • 5603 Answers
SOURCE: The reverb (or any effect) on my Fishman Loudbox
If you have a pedal input, you may be getting FALSE trips of this.
You may have a pedal jack with switch that is marginal.
TRY putting a pedal into the effect pedal input IF your unit has that and SEE if it acts stable.
These jack and jack switch problems are a pain on all these amps... any brand.
Posted on Feb 01, 2010
  • 5603 Answers
SOURCE: I bought a second hand
I don't understand your question. The "Aux in" is just that an input that goes to the power amp. Please note that the Fishman Loudbox does NOT have a headphone jack so don't be disappointed as there plain isn't a headphone jack on this unit. I would recommend that you get a small headphone amplifier for the purpose... or even go to a thrift store and get an old stereo system that has a headphone jack and use that.
Posted on Aug 01, 2011
  • 1212 Answers
SOURCE: What's your problem?I have two Fishman amps.The older Loudbox 100 single channel and a Loudbox mini. I am trying to find the service manual for the older fishman as I have a fault with it and the
Fishman iis you best bet http://www.fishman.com
You can download the user manuals, they do have a block diagram, but the scan is pretty bad.
It may end up the person looking at it is going to need to rely upon their general knowledge.
My own suggestion is to pull the chassis out so you can work on it while powering it. And then work your way through the amp with either a signal source plugged in at the input, and with high impedance headphones with test lead ends, go through each audio stage carefully. until the fault is isolated. If it is not caps or the rectifiers in the power supply, faulty ground connections to chassis or faceplate, a faulty 4558 is most probable. The headphone approach is the fastest way to address this last one. If a different series of preamp chip is used, a good source for the IC datasheets in general is Digikey http://www.digikey.com and parts too.
Posted on Feb 05, 2012
Testimonial: "Thanks for your prompt and concise reply John. Indeed I have the manual however the engineer would like to work with the schematic diagram. I have emailed Fishman and await their response..The only info I can find on the website is the manual... "
Fishman Loudbox amplifier rattle sound on bass notes
Either the speakers have loosened from the faceplate, or one or more have blown. Open the amp and tighten them down. If that doesn't fix it, remove them a take them to the nearest speaker repair shop for a checkup. If blown either have them re-coned or replace them.
Oct 06, 2016 | Fishman Loudbox 100 Acoustic Guitar...
Loud hum when I turn master above 2
Assuming there isn't an instrument plugged into it when it's humming, it will be time to have it recapped,
Oct 06, 2016 | Fishman Loudbox Mini Acoustic Guitar...
Feb 05, 2012 | Fishman Loudbox 100 Acoustic Guitar...
Low volume from Fishman Loudbox Mini mic input, using brand new XLR cable and dynamic mic. Mic works just fine on instrument input using a Hi-Z cable so problem is not mik
I have seen defective XLR cables so check it with an ohmmeter. It is possible the mic input preamp has been damaged. If that is the case, the unit will have to be repaired.
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
I bought a second hand Fishman LoudBox Performer. The problem is that the Aux-in for the headphone doesn't work. So sick... What can I do? tnx
Aug 01, 2011 | Fishman Loudbox Performer Amp Acoustic
Heavy radio interference when the amp is in use. It's worse at night. I'm using a Taylor 816 acoustic electric guitar with Taylor's balanced quarter inch to XLR cable into my Loud box Performer. Nothing...
Well, the first thing is to find if it is the amp or the guitar. Plug in a guitar cable WITHOUT being in the guitar... is the interference there? If not, the pickup of the interference is in the guitar electronics. In either case, bypass caps need to be instaalled in the offending unit near the input to bypass the interference to ground. You will need to seek someone familiar with electronics to fix this. There is a chance that the only cure will be to distance yourself from the radio transmitter. The transmitter has to be an AM radio type as FM would not generate audio in your system.
Apr 21, 2011 | Fishman Loudbox Performer Amp Acoustic
The reverb (or any effect) on my Fishman Loudbox 100 has become unreliable. It goes in and out randomly.
Jan 27, 2010 | Fishman Loudbox 100
Fishman Loudbox Performer Amplifier LBX 300 Logo
50 people viewed this question
Top Fishman Music Experts
Michial Gueffroy
Don Hart
rhodesworks
Are you a Fishman Music Expert? Answer questions, earn points and help others
