Question about Maytag Legacy Series Top Load Washer
I'm not sure what year this washer model is, but it will not go through a complete cycle without shutting off. It will go - maybe - a minute of washing before shutting off for a random amount of time. Then it will start back up and wash for another minute, then shut off again.
    Master:
  • 818 Answers
Refer to last post-denny
Posted on Oct 20, 2013
SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Posted on Aug 18, 2008
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
Posted on Sep 14, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Posted on Mar 20, 2009
dh1200s
  • 335 Answers
SOURCE: my maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
Posted on May 20, 2009
  • 4 Answers
SOURCE: Washer won't spin, Lr fault code
You need a new transmition
Posted on Jul 23, 2009
Why doesn't my front load washer complete the spin cycle?
Good Morning Friend,
I understand that your Electrolux washer will not complete the spin cycle. I will be more than happy to assist you. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If further troubleshooting is needed, I please ask that you leave the model number of your washer in your response. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Electrolux Washing Machines
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
Will not complete a wash cycle or rinse cycle, stops short
I think it maybe your lid switch. If the lid switch is out it will not spin and sometimes spin or drain. can you give me a model number so that I can further assist you?
May 12, 2009 | Washing Machines
My maytag neptune washer stop washing with 10 minutes left to go.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kemore Elite Smartwasher
Check the computer. Make sure that it is still good. You can do this with a volt meter and make sure that it is getting the right amount of volts when the unit ispowered on
Feb 13, 2009 | Kenmore Elite 45986 Front Load Washer
I just had a Frigidaire front load washer installed today model #GLTF2940FS1 and I am having a problem with the rinse cycle. When the wash cycle is completed and the spin cycle the machine will stop at 26...
hi thanks for the question make sure both water taps to washer are on check that because if the cold water if off it wont go into rinse cycle thanks the appliance doc
Sep 27, 2008 | Frigidaire Washing Machines
My Frigidaire front load washer won't start
A year later! I experienced the same problem this morning - exactly as you, Bessie24, stated. I could hear a faint humming sound and thought the lock mechanism was still trying to complete its locking function. It would know the lock function was completed when the lock trips the wee (micro) switch. I reckoned if the female portion (with switch) were a tiny bit loose, the switch might not trip, so I loosened then tightened the two screws attaching it to the carcass of the washer (as opposed to the door part) while pushing upward on the same part. This fixed my problem and i hope many others find this procedure useful.
Sep 09, 2008 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
