Question about Danze D495080AC 1 1/2'' Touch Down Drain - Antique Copper
Touchdown stopper will not pop back up - Danze D495080AC 1 1/2'' Touch Down Drain - Antique Copper
    Top Expert:
  • Danze Master
  • 36,580 Answers
The spring-loaded stopper mechanism may be clogged with hair, soap, and "gunk". Repair consists of removing the assembly, disassembling it (remembering the disassembly order of parts), cleaning all parts, and reassembling, testing, and reinstallation. Periodic maintenance will keep your stopper operating like new.
Posted on Oct 20, 2013
Remove stainless pop up stopper from bathroom sink?
Look on drain tail pipe, in the back you will find a nut that holds a ball with a short piece of rod going into drain and along piece of rod that is connected to the closure rod mounted in the faucet . Remove clip and disconnect long rod and pull long rod down to raise stopper./ Hold stopper and unscrew the nut and remove rod. Pay attention on the position of stopper piece that the short rod in inserted thru.
Nov 22, 2017 | Plumbing
Grohe drain stopper installation
Try cleaning drain with a length of wire. Strip insulation back about an inch. Turn exposed wire back to form a hook and put down drain and spin, then remove from drain, repeat until hook comes out fairly
clean. Then put drain cleaner down drain, follow instructions with drain cleaner. This should remove gunk that is preventing stopper from working correctly.
Jan 20, 2014 | Plumbing
They adjust by twisting them.
I have a number, 132020-000023, that is supposed to refer to my last explanation. Apparently you were unable to see it. I have 4 Danze South Seas faucets with touchdown stoppers that can be pushed down...
Sorry Kitty, but you've wound up in the Vacuum repair category for some reason. Probably should go back to the beginning and start over.
Oct 21, 2013 | Vacuums
The Danze touchdown stopper can be pushed down and it does not leak. It also will not pop back up no matter what, unless you can thumb-screw it backwards to get the stopper lid off. The rubber gasket seems...
This happened to mine too. I took it apart ( removed the whole part, then removed the cap ) clicked it a few times, stuck it back in, and it's worked fine ever since.
I'm going to say that it may be either a manufacturer thing, or perhaps there's some sort of build up going on.
Either way, you could try doing what I did, or contact Danze and ask for a refund. Maybe a different brand would be in order?
Oct 20, 2013 | Danze 1 1/2'' Touch Down Drain DANZE...
I am trying to use a plunger in a slow drain. bathroom lav. The pop-up valve stopper is in the way of my plunger. the Pop-up valve is a Price- Pfister. My past experience with other older pop-up valves has...
Some of the drain plugs have holes or slots in them so that the stopper can not be removed without taking the actulating lever out from under the sink. This rod is part of the linkage that is hooked to lift rod on top, Unscrew retaining nut to remove rod so you can take stopper out. Remember that any water that is in sink is going to run out of this hole once you remove rod. Good luck and thank you.
Feb 21, 2011 | Price Pfister 47 Series, Lavatory Drain...
Sink pop up waste won't close
When you pull out the stopper is it completely intact? there should be a hole at the bottom of the stopper were a rod goes through. That moves on an axis pulling and pushing the stopper up and down as you pull and push the lever. You have to make sure you get the rod in that hole for the pop-up to work. You can google pop up assembly and look for an diagram. good luck
Jun 30, 2010 | KitchenAid Home
Pop up raises only partialy, pop up not square in drain
YOU CAN TRY BY ADJUSTING THE ROD ,UNDERNEITH THE SINK ,MUST POP-UP ASSEMBLIES,HAVE A ROD COMING OUT OF THE DRAIN AND A ROD WITH SEVERAL HOLES ON ,IT TO ADJUST HOW FAR YOU CAN PULL THE ROD UP ,WHICH IN TURNS SHOULD MAKE THE STOPPER GO DOWN,ALSO A COMMON PROBLEM IS THERE IS TO MUCH HAIR AND TOOTHPASTE STUCK ON THE STOPPER ITSELF,SO SIMPLY UN SCREW THE NUT, THAT IS HOLDING THE ROD INTO THE DRAIN ,THEY LIFT UP THE STOPPER,THE STOPPER SHOULD NOT BE ABLE TO BE REMOVED WITHOUT TAKING THE NUT AND ROD OUT ,IF SO YOU MIGHT HAVE TO REPLACE THE WHOLE POP-UP ASSEMBLY
Mar 17, 2010 | Plumbing
Pop up stopper does not work. It comes off the
you might want to check the retaining bolt that holds the rod to the raising and lowering arm. Located under the sink on the back side.
Nov 08, 2009 | Kohler Caxton Undercounter Lavatory Sink...
Gas tube came out of gas tank
If the rubber stopper is still plugged into the tank pry it out go to a small engine shop and buy new gas line.Thread the new line into rubber stopper to poper length,plug filter (new)on end that is going in tank then pop he rubber stopper back into the tank body.Have done hundreds and it isn't hard,you may need sone WD 40 on stopper to thread line and popping stopper back in .Good Luck
Jul 19, 2009 | Homelite Mighty Lite Lawn Trimmer
Danze D495080AC 1 1/2'' Touch Down Drain - Antique Copper  Logo
143 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
