Question about Jandy Aqualink Pda P8 Wireless Pool or Spa Control Control System
I think air got into the pool filter and now it has no suction what do I do to resolve the problem
    Problem Solver:
  • 12 Answers
There should be an air bleed valve at the pump. If not check or loosen the filter top to get the air out then start the pump after tightening the failter.
Posted on Oct 20, 2013
Pool pump problem: Cavitation sound in spite of no blockages in suction lines. Replaced many parts and replumbed with no success.
me id make a temporary suction line that could be dropped right in the pool (half union,suction hose with brick tied on end) this would easy test the underground pipes/valves for any spider cracks (air inlets) observe the output using the ole pump if no improvement then sorry that ole pumps gotta go
frequently on old installs I find that winter weather wasn't so kind to the plastic pipes and they develop spider cracks(tiny ) this provides a path to suck air into line
Oct 20, 2015 | Pool & Spa
Loosing pump suction when vacuum pool
keep out all the air inside the lines. When Pumps loose power suction is because there is some air inside the lines.exaust the air inside the lines
Aug 08, 2014 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
Polaris 9300 Sport Robotic Pool Cleaner stops in water after running about 10 seconds.
Check your pool cleaners filter screen in the in-line filter system and make sure that it is clear of debris. Also check the skimmer, basket, pump basket, and pool filter to make sure that they don't have anything blocking suction. A loss of suction would definitely make the cleaner stop moving. Make sure that your hoses and connections do not have leaks that could be causing air to to escape.
Oct 10, 2011 | Polaris 3900 Sport Pool Cleaner ()
When the pump turns off dirty water "belches" back
Thank you for posting your question here on Fixya.com.
You may have a combination of problems. If there is air in the filter then when you shut it off this air expands and forces it out the skimmer. This is made worse if the filter needs to be cleaned or the return to the pool is restricted in some way. To reduce the amount of air that is in the filter any suction leak should be corrected and the air relief port(if it has one) inside the filter should be cleaned. Sometimes this is called the sock or screen, etc. I hope this helps.
If this answer does not resolve your issue, please respond with additional information before rating the answer. Positive feedback is especially appreciated once your problem is solved! Thank you.
Aug 28, 2011 | Hayward SAND FILTER, PRO SERIES
My sand filter no prime new motor above ground pool
The most common causes of no prime are that the filter pot is not filled with water (don't forget to put the cover with a gasket on), there is an air leak in the pipes/valves between the pump and the pool, a plug of leaves or other debris in the suction line, or the pump is installed so high in elevation relative to the pool that just a little of the above issues will prevent it from priming. I hope this helps.
If this answer does not resolve your issue, please comment with additional information before rating the answer. Positive feedback is especially appreciated once your problem is solved! Thank you.
Aug 25, 2011 | Hayward SAND FILTER, PRO SERIES
WWas working just fine then hooked up vaccum and cleaned pool now the skimmer does not have any suction-- water blows out other side just fine and I have gotten all air out of lines--- any ideas
Depending on how much you vacuumed, your filter may just need to be cleaned. The filter on these units are not very big, so they can get dirty fast. Make sure it is cleaned out. Make sure skimmer basket is not clogged up, and make sure none of the flexible hoses are crimped. Also make sure there isn't anything stuck in the impeller. A stick, twig, or piece of toy, etc, can get stuck and cause low flow. Check for leaks between the suction side of the pump and the pool skimmer. One more think you might want to check is for leaks on the suction side while equipment is off. a leak here will let air into system and effect flow.
Sep 24, 2010 | Intex Krystal Clear Model 635 Pool Filter...
I have a 15x48 intex metal frame pool with a 637 pump that uses A cartridges. I have cleaned out the filter and the skimmer and after hooking everything back up and bleeding air out of the lines I plugged...
if the system is consistently blowing air into the pool in large quantity, you most likely have a suction side leak that is allowing the pump to **** in air and return it back to the pool. try shutting the system off and inspect the suction side for any water leaks, that should lead you to any air leaks on the suction side. try turning the pump on and off a few times to catch any water spurting out of the suction side. Also, make sure the skimmer is now enough to not create a vortex and **** in air as well. Hope this helps.
Aug 24, 2010 | Intex 1 "a" Filter Cartridge Pool Pump...
Pump won't **** when attach the hose
Its very possible that it is not a problem with the pool pump, but a problem with the conncetion to the vacuum hose. If you are losing pressure only when you vacuum, make sure that your connection is secure and you have no holes, cracks, etc. in your line. If you think that there are definate pool pump problems, check for the following problems.
1) Clogged or restricted strainer or suction line
2) Plugged or restricted discharge line of filter (high
discharge gauge reading).
3) Air leak in suction (bubbles issuing from return fittings).
4) Pump operating underspeed (low voltage).
5) Plugged or restricted impeller.
May 31, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Pool doesn't have pressure. Checked pump no blockage. Had the pool guy put air through the lines and no clog. Filter has zeobrite sand, but it's green? Pool company said it shouldn't be green. We are going...
Hi my name is Juan and I was a pool tech in california now located in georgia and let me try solve this if your filter is dirty it created a high pressure in your filter gauge with poor suction to check this bypass the filter and see if suction increase sometimes your gauge is bad and is not showing the true reading but if is good and pressure is to low then is so clear you have a suction leak try to replace the pump lid O ring and if you have spa check the intake valve where you select pool or spa if you don't have spa then the air leak is in the pipe connected to the pump suction side believe me this is a common problem
Jun 15, 2009 | Pool & Spa
Jandy Aqualink Pda P8 Wireless Pool or Spa Control Control System Logo
37 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
