Question about Amana ACS3350AS Gas Kitchen Range
Code f9 appears display shows "locked' - Amana ACS3350AS Gas Kitchen Range
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Google Amana error code F 9. Looks like a door lock situation which sometimes occur after self cleaning.
Get that info on meaning of F 9 so more people can help you. Or there might be someone with his error code book at the ready.
Good luck.
Posted on Oct 21, 2013
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
Jenn-Air JGR8855 oven light stays on
F9 is for the door lock relay fault. Does the lock work OK? Is anything else acting funny on the unit?
Nov 22, 2012 | Jenn-Air JGS8750 Gas Kitchen Range
Door lock stuck
Hi etmscholten,
Please check the door latch components. The F9 error code appears when there's a problem with the door latch.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2010 | Maytag MER5775Q Electric Kitchen Range
When I try to set a temperature, F9 appears. I have tried to turn off power by flipping circuit breaker. The power was off and I set a temp, then turned it off and F9 appeared again with "lock." Any...
The most common cause of a F9 error code is a problem with the door latch circuit. There could be a pinched wire for the circuit causing a short or the door latch motor is defective. Sometimes a problem with the ERC can cause this error to appear. Possible problems can very slightly from manufacturer for this error code but almost all use the F9 error code for the oven door lock.
Jan 14, 2010 | Ovens
The F-9 code comes up when we try the oven. We
Hi tessjon,
The F9 fault code is about the door latch, please check the door latch components.
Hope it helps.
Jan 09, 2010 | Maytag MER5775Q Electric Kitchen Range
F9 is appearing in the clock window
HI. This will code is indicating that the oven door lock mechanism is experiencing difficulties. Check the wiring to door lock switch (the wire harness may be connected wrong, or loose). Check for stuck lock switch, as well.If the wiring is not loose, or connected improperly, this will lead to a failed door lock mech. it will require you, ro your service tech to replace it, in this case.
F-9 Oven door lock failure
Dec 07, 2009 | Whirlpool Ovens
Hi, my GE Profile Mod# JBP90GV2BB S/N ZM223214G began beeping this morning and posted an F9 code in the display. The stove hasn't been used in 2 days. What does the F9 code indicate and what ccan I do to...
F9-- Failed Lock switch detected.
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
If the wires are ok and, the switch is not stuck, replace it asap.
Jul 10, 2009 | GE Profile JTP18 Electric Single Oven
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Amana ACS3350AS Gas Kitchen Range Logo
76 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
