Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
The thermostat don't work.I change the batteries and still no works.The thermostat make a noise
    Master:
  • 450 Answers
If this is new, check and see if any of the wires are touching each other. It could be your furnace. But 1st I would change out the thermostat. Thaey are $30 to $70 and it takes about 5 minutes to change one out.
Posted on Oct 21, 2013
How do I change the battery on Honeywell Thermostat T8001C?
According to the manual for the model series (see link), only the T8002 Model has batteries. They are accessed from the right side of the thermostat. See page 14.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1431.pdf
Jan 10, 2015 | Honeywell T8001C1019 Programmable...
Rth111 does not turn on when cold
too cold for batteries or they are low. Litium Ion work well in the cold but check tstat instructions for compatibility.
Jun 12, 2017 | Honeywell Programmable Thermostat Heater
The check engine light was on, so I changed the thermostat on my 03 Envoy. Now the air conditioning won't work. It blows hot air out of the inside vents, with the heater turned off.
When you changed the stat, you probably disconnected the battery. This caused the HVAC to lose its calibation and during the recalibration, one of the mode control actuators or the associate doors failed. You can try to force another recalibration by doing the following;
1) turn all HVAC controls and switches to their OFF or CCW positions.
2) disconnect the battery for a few minutes (>2 min.)
3) reconnect battery and don't touch any HVAC controls for a few minutes.
If this does not return the system to working order, you will have to have the actuator(s) replaced. Attached is a diagram of their locations.
Oct 17, 2011 | 2002 GMC Envoy XL
Unit has worked fine for a month. Today it makes a 'getting juice' noise for around 3 sec and then turns off without running obviously. The fan is not frozen-spins easily. The thermostat, a...
The compressor is trying to start and cannot... change the capacitor and if that don't work then the compressor is bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 25, 2011 | Heating & Cooling
I have a Rheemglas 250 litre electric hot water system. It seems to have stopped working. Is there anything I can try to get it working again? Otherwise I'll need a technician but hoping it's...
Make sure you have power to unit. Check the breaker in your breaker panel and look around unit for a timer or disconnect that may be having problems. I don't know if you are electrically inclined so if you are scared to take off front panel, don't do so. If you believe your breakers and/or any disconnects etc., are on and working, you can remove the screws holding the inspection panel on and press the reset button on the thermostat. There may be insulation covering the thermostat. The thermostat should have a plastic cover on it shielding the live wires while making it possible to press the reset switch. Again, if you are electrically inclined, you can check for power at the thermostat. These are the simple things you can check. If you reset the button, within about 3 to 5 minutes, you should here noise from inside the unit if it is working.
Jun 05, 2011 | Rheem 81VP6S/430126 Water Heater
Display not working after battery change
some have a small reset button on the back where you push it with a pencil tip. That may help!
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
No display on Robertshaw 9600; unit seems dead/furnace works
Hello
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
My fridge is blowing out cool air but not cold air
There is several things can cause that To tested first unplug your fringe Remove the panel behind your fridge Reconnect the fridge Touch your compressor us the big black round thing on the back Does it field vibrating and making noise? If yes that means you have a bad compressor or refrigerant leak If it makes clacking noise or a laud buzz noise then stop Deftly you have a bad compressor If make no noise or vibration ones of ever First remove the thermostat and make a bridge in between the thermostat cables live the green one alone is just ground If your compressor start working then buy a new thermostat if don?t change any thing Remove the black box on the side of the compressor and you shut see thee plugs or one plug whit thee holes use a voltmeter and check for power, You shut get around 120vots between tow terminals if you have power Go to the local appliance part store a buy a ?hard star kit? if your compressor doesn?t start you have a bad compressor. If you don?t have power you need to change either your defrost timer or control board Depending of the fridge model
Jun 08, 2009 | Kenmore 60721 Refrigerator
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
75 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Heatmeister99
Level 1 Expert
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
