Question about HP OfficeJet 6210 All-In-One InkJet Printer
This has been a great printer but the hinge on the lid seems to be broken and the "lid" won't stay seated properly so it always s hows "close printer door". You can hold it down but that isn't practical when printing! Any way to fix that hinge? My husband took a look at it and he's pretty handy but says there is o way to fix it. I find it hard to believe I have to scrap this great printer for such a minor issue!
    Top Expert:
  • HP Master
  • 34,781 Answers
Failure of a relatively minor part helps maintain replacement product flow from the manufacturer. I am also facing replacement of a 10 year old HP printer! You might be able to get a replacement part from another printer but that is, at best, a long shot.
Posted on Oct 20, 2013
4 Suggested Answers
  • 24 Answers
SOURCE: Printer Door
1. Open the back door of the printer and roll the rollers 5-6 times upwards.
2. Open the top cover of the printer and take out the ink carts fromthe prinetr and clean the copper contacts of the ink carts and the printer ink cart slot.
3. Shut the back door and after inserting the ink carts close the top cover as well.
4. Delete the icon of the printer from the computer and unplug and replug the usb cable from the printer.
Posted on Feb 03, 2008
SOURCE: hp laserjet 2600n printer showing message door open
there door censer problem. i fix new censer
Posted on Jul 10, 2008
  • 113 Answers
SOURCE: Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Posted on Feb 28, 2009
The left hinge is broken on my pro905 how do you fix it
My 905 left hinge is broken too. Scanner lid/paper feed is now out of alignment and consistently jams paper being fed through it.
Oct 02, 2012 | Lexmark Platinum Pro905 multifunction...
One side of the printer will not close
The hinge underneath could be broken the only way to fix this is to remove the plastic hinge.. You will need to unplug the printer and examine it, the broken hinge is likely to be impeding the lid from closing,
Oct 01, 2012 | Dell 948 All-In-One InkJet Printer
Lexmark pinnacle pro adf cover hinge won't close
Go to this link on You Tube and watch the revised video. It will correct the problem for you.
Jun 03, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
Hp 6310 repair hinge
Generally the hinge will fall into a groove when lifted up. If it will not close you can generally lift the lid a bit higher and dislodge the hinge from these grooves and it should close.
Oct 19, 2011 | HP Officejet 6310 All-In-One InkJet...
The scanner lid won't close properly. I see the right back corner of the lid has popped out of it's socket. how can I fix this?
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Aug 26, 2011 | Lexmark X3470 All-In-One InkJet Printer
Lexmark 7600 printer cover is not seating properly after installing printer cartridge
The two hinges are attached to the back of the printer by two screws. I removed the two screws and lifted the top off, freeing the two hinges (the one on the right was broken so part of it stayed in the printer). There is a restraining line on the right side that keeps the top from coming completely free of the printer, but it can be worked around while still attached. I removed the broken pieces and the internal spring from the right side hing. The spring is what was keeping the top from seating correctly. I assume you could order a new hing, but I reassembled the printer without the spring and the top seated properly. The printer works, but I will now need to be very careful when replacing the ink cartridges because of the missing hing on the right side.
May 10, 2011 | Lexmark International Lexmark 7600 Series
The hinge part of the toilet seat installed alright---but once the seat was connected to the tank, i tried to open the lid and it just fell off---the quiet close "dowels" for lack of a better...
Hi, Please don't take this the wrong way but did you install the hinges the right way? I fit bathroom suites for a living and have done this a few times wrong by putting the left hinge on the right side and vice verser. Sometimes the instructions are not very clear in explaining which side is left on the seat, as a result even though the toilet seat is closed, the springs are set backwards and are in fact in the up position. Double check the instructions once more, and just have a look on the hinges and seat because sometimes they have a small 'L' sticker on the hinge and an 'L' sticker on the seat and lid to correspond which hinge goes on which side. Hope this is of help to you.
Jan 11, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
My printer says doc cover open on a mfc 8820d how should i fix.
You have to close the ADF. If the ADF is closed, then the left hinge is probably broken. Look for "MFC-8820D hinge" to find the solution in FixYa.
Jan 10, 2009 | Brother MFC 8820D All-In-One Laser Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
151 people viewed this question
Seeker5211
Seeker5211
