Canon Error Codes 13,242,0 on a MG2200 - Office Equipment & Supplies
I have a Canon MG2200 and I can't scan. How can I get it to scan. I really need to scan. Can someone help me.
I have a PIXMA Canon MG2220 printer. I lost the manual. All I need is step by step information on how to use the scanner on the printer. Its hooked up and on. Everything is already installed. Printer works good. Just need instruction on how to use the scanner
Nov 03, 2014 | Canon PIXMA MG2220 Inkjet Photo All-In-One
What do I do about an almost full absorption situation for the Canon Pixma MG2200 and what is it?
Every time you use the printer, it shoots out a small amount of ink to an absorbent pad - this cleans the ink jets. Over time the pad becomes full of ink and needs to be replaced. You'll need to get the printer serviced.
Oct 13, 2014 | Office Equipment & Supplies
How do i get the ink cartridges in as canon pixma mg2200 to come out have followed instructions but they won't come out
The color cartridge (241) needs to be on the left and Black (240) right as it sounds as though they are in the wrong way as you are having trouble removing them either that or you put them in backwards put in label up with the number on the label facing U
Aug 08, 2014 | Canon PIXMA Office Equipment & Supplies
Canon pixma mg2200
please check for paper tray
Nov 05, 2013 | Office Equipment & Supplies
I have an MG2200 Pixma printer. It stopped printing in the middle of a delayed queue because it ran out of paper. I put the paper in and then I think I turned it off and then on again. It will not...
Log off your computer so it shuts downs.
Log back on
Go to control panel
-Find Printers
-Click on Printers
Plug your printer into computer
-Printer should show up on screen
-Right Click on Printer and set as default
-Left Click on printer
-Click on see what printing
-Cancel job that's printing
Close printer
-Try to print again
Nov 02, 2013 | Canon Office Equipment & Supplies
Canon pixmma MG2200 printer alignment
just replaced the ink and images are faded when printed out, cleaned the ink cartridges and ran threw a cleaning sheet but still comes out faded
May 04, 2013 | Canon PIXMA Office Equipment & Supplies
How to put inks into canon pixma mg2200
use black ink only. Beacuse sending signal color ink is empty
Nov 29, 2012 | Canon PIXMA Office Equipment & Supplies
Where i can get all error codes for canon ir 400 with solutions
From what I can see, canon support does not publish those for local consumption. Seems they want their techs to have the information only. You might just try calling canon support and asking if they would sell you a copy of the manual.
Alternately, you could look up each error code as it happens on the internet. Here is an example of a list of error codes and their causes;
http://canon330400.blogspot.com/2011/09/error-codes-for-canon-ir-canon.html
Mar 22, 2012 | Canon imageRUNNER 400S Copier
419 people viewed this question
k24674
jasbo
jasbo
