Question about Dell OptiPlex GX270 PC Desktop
Cable monitor signal - Dell OptiPlex GX270 PC Desktop
    Master:
  • 359 Answers
What exactly is your issue. I do not see a description of a problem here.
Posted on Oct 20, 2013
Problem with the monitor
hi,
first of all,try to connect the cable to other device(laptop) to see if is working,because if you receive the message"No signal" then the monitor is working but the cable/signal did not cross to the monitor,then is working with other device then try again or check if you can connect the monitor with different port if you monitor has one vga/dvi or hdmi.
Aug 25, 2014 | Acer Veriton M460 Micro Tower Core 2 DUO...
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
No signal conecting wii with component to samsung p2370ms monitor
Remove the memory card from the wii , try again and it will work !
Oct 11, 2012 | Nintendo Wii Console
I have a e machines desktop that will not boot up. I turn it on and the monitor says no signal. I think it might be stuck in hibernation mode. The fans on the tower start but thats about it. If some one...
No Signal means you Display or Monitor is not getting signal from Video Card.
In this case:
1. Check if all the cable are properly plugged in. Check on both monitor and computer back. 2. Check if cable is not broken. 3. Try unplugging cables and plug them back. 4. Try some other monitor or cable. 5. If cables are fine than problem could be with your video card.
As you are getting No Signal that mean your monitor is working fine. Problem is either with cable or video card.
Jul 06, 2011 | Computers & Internet
I have connected the cables....no display
disconnect the signal cable and power on then see the massege on monitors screen "NO SIGNAL CHECK THE SIGNAL CABLE"if it appears then monitor is ok if not then monitor is faulty check the signal cable and replace it if faulty problem will be solved
Jun 16, 2010 | Samsung SM943N 19" LCD Monitor
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
No signal
This problem requires you to test both the monitor and the signal input form you cable tv setup. Set the monitor up on a computer and see if it works properly. If it does then you may have a problem with the signal conversion of the cable tv to the monitor. It also could be a weak signal that drops below the monitors sensitivity levels. Have your cable tv repairman check the signal levels on your lines. Another way to test this is to hook up is with a different monitor to test your setup and see if it works. If after testing you find, the monitor does not work properly, then you need to have it serviced. Hope This Helps.
Mar 12, 2009 | Envision 19" Widescreen Flat Panel LCD...
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Acer monitor lcd
no signal means there is no communication between your monitor and your system unit.check and be sure your monitor signal cable is firmly connected,if nothing happens, try the monitor on your friend's system.if no change then try and replace the monitor signal cable, eyo7 eyoifiok2005@yahoo.com
Feb 28, 2007 | Acer Professional P211 21" CRT Monitor
Dell OptiPlex GX270 PC Desktop Logo
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
