Question about Behringer C1U Microphone
I cannot use my Behringer C-1U. Windows (nor Xp or Win 7) does not recognize it. The drivers were properly installed. When I connect the microfon to the computer through my USB port (2.0) the green light appears, but only for about one second and after that slowly dissapears, so the microfon cannot be installed. What should I do? How can be Phantom Power activated (if that's the problem)? Thank you.
4 Suggested Answers
  • 12 Answers
SOURCE: Adobe Audition 3 Not Sensing Mic
Check the input and output settings. Look in the preferences or settings menu for "i/o settings" or "i/o setup." You're going to set it from the default internal mic input to this one. It sounds like it may be that simple.
Posted on Jul 29, 2009
  • 3 Answers
SOURCE: my behringer c1u doesn't have
Answer from official Behringer support:
The green LED is fine. The newer units have green LEDs.
Please download and install asio 4 all from:
http://www.behringer.com/EN/Products/C-1U.aspx
We hope that we have been able to help you with this information.
Posted on Feb 19, 2011
  • 149 Answers
SOURCE: I have a Behringer Mic
How to Operate a Behringer C-1U
The Behringer C-1U is a USB condenser mic for recording individual instruments. A condenser microphone is a mic that uses vibrations produced by sound to change the distance of internal plates that produce signal. Condenser mics typically require an extra change, known as phantom power, to operate. Since the C-1U is USB powered, phantom power is not needed. The Behringer C-1U has a frequency response that favors sounds around the 10KHz range. This heightens the clarity of recorded signals due to the microphone's treble boost.
Things You'll Need:
* Computer with USB 2.0 port
* USB cable
* Recording software
Instructions
Turn on the computer. When the operating system loads, connect the microphone.
Install any necessary drivers for the C-1U. This will happen automatically when the device is connected.
Select the Behringer C-1U as an input source in any desired audio software. In Windows, click the "Volume" icon in the task bar to open the mixer. Select the C-1U as the primary input. On Macs, use the "Audio/MIDI Setup" in the "System Preferences" menu to select the C-1U as the primary input
Note: make sure you activate the phantom power on the mic. That's the only way to power up the microphone.
Have a nice day.
Posted on Feb 25, 2011
Why Behringer C1U not recognized ?
Did you install the mic's drivers before plugging the mic in? Have you tried it on 32bit operating systems other than Win 7? I don't think it will be an audio driver problem ie: asio4all. But because the OS doesn't recognise the driver automatically it might indicate where the problem lies. I am not familiar with this particular mic ( I use AKG cs1000s with Zoom R16 audio interface ) but I know there can be issues with some 64 bit systems and certain audio hardware. Nothing in the Behringer forums?
Aug 21, 2014 | Behringer C1U Microphone
Driver microfon
Is this a OS Upgrade? You can find the drivers here: http://support.toshiba.com/support/modelHome?freeText=2059994 Sometimes you can use Win 7 driver, you must modify compatibility to Win 8.
May 11, 2013 | Toshiba Satellite P305-S8842 Laptop...
How do I get my Behringer C-1U mic to work?
I'm having the same problem, however I can say that Phantom Power is out of the question. the c-1u is a variation of the c-1. The difference is that the u doesnt require phantom power
May 06, 2012 | Behringer C1U Microphone
I have a Behringer Mic C-1U and its not powering up!
Things You'll Need:
* USB cable
Instructions
Have a nice day.
Feb 25, 2011 | Behringer C1U Microphone
Windows 7 not recognizing audio devices
please download proper sound driver for win 7 and instal properlly
Jan 11, 2010 | Televison & Video
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
Running digi 001 on windows 7
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Mar 17, 2009 | Digidesign Mbox 2 Barebone
Behringer C1U Microphone Logo
83 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
