Question about Sewing Machines
My elna 500 will only sew 2 of the 12 to 14 stitches it is capable of. It will sew straight and zig zag. I turn the dials to the settings in the manual using the different color areas on the dials but the decorative and utility stitches only sew out in a zig zag pattern. What could be wrong with the machine? truittsusan1@gmail.com
  • Sewing Machines Master
  • 7,365 Answers
It sounds like the decorative cam or gear is damaged.. it would be a good idea to have the machine checked
Posted on Oct 21, 2013
4 Suggested Answers
  • 1027 Answers
SOURCE: How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
HOW DO YOU CHANGE THE STITCHING FROM STRAIGHT TO ZIGZAG
Check that your sewing machine is even capable of zig-zag. Some machines are straight-stitch only.
Consult your owner's manual.
If your machine can do zig-zag, somewhere there is a dial or setting called "stitch width" that will determine how wide the zig-zag will be.
May 21, 2016 | Sewing Machines
How do I get it to zig zag
There is a dial or a lever that you turn it to. It usually has a straight line picture for straight stitch and a zig zag photo for the zig zag stitch.
Mar 01, 2015 | Sewing Machines
Set zig zag stitch on Elna Elina 40
I have looked but can't see a manual, but looks like push button stitch selection on front of machine, often it will be same as straight stitch, but need to take stitch width from 0 to 4
Feb 27, 2015 | Elna Sewing Machines
How do a i do a zig zag stitch
Simply turn the dial to get the zig zag setting. Manual in the linky
http://www.janomeflyer.com/pdf/Elna%20eXplore%20320%20manual.pdf
Oct 07, 2014 | Elna Sewing Machines
Elna 6003
Check to see if your needle is bent.
Feb 06, 2013 | Elna Quilter's Dream 6003Q
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
My Elna SU will only do straight stitching it will not zig zag
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 02, 2011 | Elna Quilter's Dream 6003Q
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
I have and Elna su sewing machine and i can't get it to zig zag. Please refresh my memory on the settings i should have it on.
Depends on which SU you have, but you need to move the stitch selector to Zig Zag, then set the stitch length to 2.5 and the stitch width to at least 2.
On the earlier models the stitch selector is a wheel inside the flap on the top of the machine, on the air electronics, it is a coloured dial.
If this doesn't help, check if you've inadvertently moved the needle position to the side setting.
Aug 23, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
96 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
