Question about RupseTM For VW: New BORA / PASSAT CC / PASSAT B6 / JETTA A5 / GOLF PLUS / GOLF 5 / Golf GTI / Golf R32 / Scirocco / Tiguan / Touran / Caddy / EOS / Rabbit / SKODA: Octavia Limousine / Octavia Combi / Fabia Limousine / Fabia / Roomster/ Praktick / SEA
I need a rebult volkswaggen tiguan engin - RupseTM For VW: New BORA / PASSAT CC / PASSAT B6 / JETTA A5 / GOLF PLUS / GOLF 5 / Golf GTI / Golf R32 / Scirocco / Tiguan / Touran / Caddy / EOS / Rabbit / SKODA: Octavia Limousine / Octavia Combi / Fabia Limousine / Fabia / Roomster/ Praktick / SEA
2009 tiguan changed battery now it wont start
Might need to have your keys programmed. Does anything else work in your car ? Does your engine turn over ? If yes, do you have power going to the starter ? If no, may want to check fuses. More detailed information would help
Oct 30, 2016 | 2009 Volkswagen Tiguan
2011 vw Tiguan sputters at around 25mph. Engine light came on. Code p0302 Please help
check all spark plugs or replace them test coils by unpluging them one by one while engine is running to detect misfire
Nov 29, 2014 | 2011 Volkswagen Tiguan
2011 vw tiguan problems
When was your last oil Change, and what kind of oil was used? If too high a weight of oil was used, it will be very think in the cold, and can impact engine performance, also if the engine oil is too thick, it will not be able to be pumped to the upper parts of the engine, meaning you will hear your cam make noise on the lifters.
Aug 22, 2014 | 2009 to 2011 VW Tiguan Tire Pressure...
My 2011 VW Tiguan is stalling out while reversing out of driveway...occasionally. The car is already warmed up. It's an automatic 4cyl turbo engine
First is your car still under warranty? If not we are working on an 09 Tiguan that wants to sometimes wants to die out at stops.We are replacing the in tank fuel pump and fuel pump control module.
Jan 29, 2013 | 2011 Volkswagen Tiguan
How to change air filter on tiguan
The air entering the engine passes through the air filter so that it is free from any foreign particles. This is very important as any impurities inside the engine can cause trouble in the ignition process. So it is important to clean the air filter frequently and replace it at specific intervals. Here is a Maintenance Guide How to Change the Air Filter of Your Car
For more clarification check out this video
Feb 10, 2012 | 2010 Volkswagen Tiguan
How I reset oil pressure light on my 2009 Tiguan
You don't, it is under warranty, take it to a dealer before you fry the engine. Either the pressure sensor or the pump is bad, either way needs immediate pro attention.
Jun 22, 2011 | 2009 Volkswagen Tiguan
RupseTM For VW: New BORA / PASSAT CC / PASSAT B6 / JETTA A5 / GOLF PLUS / GOLF 5 / Golf GTI / Golf R32 / Scirocco / Tiguan / Touran / Caddy / EOS / Rabbit / SKODA: Octavia Limousine / Octavia Combi / Fabia Limousine / Fabia / Roomster/ Praktick / SEA Logo
29 people viewed this question
Top Rupse Computers & Internet Experts
David Payne
David Payne
Are you a Rupse Computer and Internet Expert? Answer questions, earn points and help others
