Philips GoGear SA3020/37  MP3 Player Logo
Anonymous Posted on Apr 25, 2009
I just bought a Philips GoGear 2GB MP3 player today, i just can't figure out how to get music on it It keeps giving me an "error" message! This is so frustrating...god.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
188
Points
Connect the usb. Install drivers if necessary from CD included in package then browse "my computer" for the "phillips drive". Copy your MP3 files to the "music" folder.
4helpful
My philips ipod gogear 2gb showing I/O device error.how to solve this
my philips gogear vibe 2gb is not swiching on nor it is showing in my laptop plz give me the address of philips service center in meerut (uttar pradesh)
1helpful
3answers
Philips GoGear HDD6330 MP3 Player will not sync music files onto it? How do I fix that and has deleted all previous ones! Please help>
This could be the player's connection mode in combination with your synchronization software. If you are using Windows Media Player or Philips Songbird to sync, the player will need to be set for MTP connection mode. Most other software that works with regular flash drives will need the player set for MSC connection mode. Whatever you are using, simply try the other mode.
To change the connection mode, select "PC connection preference" in the Settings menu of the player.
If you found this information helpful, please indicate as such.
GoGear 2GB how do I down load music from my computer?
hi there, the easiest way to do this is to use windows media player and download some music. After downloading music, click the sync button.
23helpful
2answers
Philips 8gb Gogear SA3085/02 -"DRM License not available"appears
In your Windows media Player go into tools and select options. Select rip music and untick copy protect music. The music you have in WMP wont work. you will have to put them in again after you made the changes. Hope this helps
Music files not supported
if you cannot download songs to your mp3 player you need to find a software program to configure them into mp3 form files.
1helpful
My philips gogear 2gb mp3 player will no accept any format
maybe try uninstall program on pc then put instalation disk back in and reinstall
I had already saved some songs on my gogear 2gb, and when i plugged it in to delete those and add some more, i accidentally deleted the music file from the mp3 player.
Unfortunately, deleting that music file is irreversible - you can try running the Repair in Philips Device Manager, but it most likely will not work. Call Philips and see if you are in warranty.
-Tha Mp3 Doctor
MY philips go gear 2gb music player does not getting on.
Run a Repair in Philips Device Manager - the program came on the installation CD.
If that fails the first time: Unplug the GoGear from the PC. Uninstall all Philips software in the Add/Remove Programs section of Control Panel. Restart your computer and reinstall the software. Replug the GoGear. Re-run the Repair.
-Tha Mp3 Doctor
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
