Question about Dell Inspiron Computers & Internet
110 volt plug wiring
Board on standby
    Master:
  • 359 Answers
What exactly is the issue you are facing? I do not see a detailed enough description to help.
Posted on Oct 20, 2013
How to hook up electrical? 220v single phase? What color wires on which connections of the plug?
Identify the prongs. If you have wired a 110-volt fixture or plug, then you are aware that the different prongs connect to different colors of wires. The same principle holds true for 220-volt plugs, and this is very important to keep from tripping the circuit breaker. A three-prong plug will connect to two colored wires that each supply 110 volts and a bare copper wire which is the ground. One of these colored wires will be black, while the other one should be red, white, or blue. The four-prong plugs connect to a black and a red wire that each supply 110 volts, a white neutral wire, and a bare copper ground wire.
Read more : http://www.ehow.com/how_6830969_wire-220_volt-ac-plug.html
How to Wire 220 Volt AC Plug eHow
Dec 16, 2015 | Ovens
How do i connect to 110 volt power source
if the unit is a 110 volts unit attach a 110 volts plug to the power lead and plug it into a wall socket
If you have to ask then get an electrician to do the job
If it not 110 volts utility supply then you will definitely need the services of an electrician to wire up a converter to the different power supply.
Sep 13, 2015 | Heating & Cooling
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
Plugged 110v dishwasher into 220v
When you have a 220v outlet there are two wires that both supply 110volts, thus the 220volt rating. 110volts uses 1 wire that supply's 110 volts and the other wire is a "neutral" what is a non current carrying conductor. In other words there is no 110 volts on the second wire. Most of the time if you supply a 110 volt appliance with 220 volts you most definately fry something if not everything. Probably the main thing that blew was the control panel be it a computer board, dial switch etc. Sorry for the bad news but it might be cheaper to replace the unit than having it looked at and repaired
Feb 05, 2012 | Whirlpool Dishwashers
I have a american standartd and the burner goes on but the blower never starts. what should I look for first? the thermostat or capacitor?
Follow the wires from the blower to the circuit board. If there are more than one speed on the blower, unplug the current speed and plug in the wire for a different speed. The circuit board is usually marked Heat, Cool and Park. Take the one on Park and put it on Heat. You can also check for 110 volts on the Heat terminal after the burner runs for about 90 seconds. You can also test the blower by energizing it from a 110 volt source.
Jan 02, 2011 | American Standard WCZ036F Air Conditioner
What is the polarity and voltage setting for the hot water on demand system
Well if you buy a 220 system it will be 220 volts.
All the bigger systems like for whole house will be 220.
some smaller under sink models will be 110.
There is no polarity since it is AC. If you find something that says polarity on a on demand water heater then somebody at the factory is smoking something.
110 has 3 wires. all tests need done with a multimeter on the AC setting.
Black wire will be 110 volts AC, White wire is neutral and green wire is ground.
220 system also has 3 wires. Colors can vary a bit here but usually it goes like this.
Red wire is 110 AC - Black wire is 110 AC and white wire is Neutral or ground.
Test to ground they read 110 Volts AC test to each other they read 220 AC because they are out of Phase to each other.
PLEASE note. Always get a certified electrician to work on these units. If you feel you are just as good as any electrician, please make sure you have a family member nearby with a phone that can dial 911. 110AC can kill you and 220 AC can kill you faster and deader.
To know whether any particular unit is 110 or 220 we would have to have the model number to look it up. Some can be either and in this case the only way to know is to take the junction box apart. If it is just plugging into a regular wall outlet then it is 110. If it looks like a special plug or like a dryer plug then it is 220.
Hope that helps. Have a great weekend.
Apr 16, 2010 | Coleman Hot Water On Demand
Is kenmore 98702 220?? or 110???
if it has a small 3 prong plug then it's 110v for the washer but the dryer should be factory 220 volt however many were sold wired too! 110 volt! just look at the plug small plug 110v large 3 prong! 220v
Jan 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Rm2807 rv refrigerator gas works but the a/c is not working
Check the 110 volt wire for flaws. Take a volt meter and check the recep that the fridge plugs into for power, should be 110 volts or so. +/- 10%. If you have power at the recep problem is in the fridge chord or circuit board fuse or circuit board. Also check the 110 volt breaker in the coach at the service panel.
Mar 29, 2009 | Dometic RM2852 Refrigerator
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
