Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
Wires won't stay in new switch - Westwind Classic Hugger Polished Brass 52" Ceiling Fan
    Genius:
  • Westwind Master
  • 1,617 Answers
Take it back and get a new one. If you're buying one off the rack, then it's probably going to be the wrong one anyway.
Posted on Oct 21, 2013
Power window won t stay up
May need a new window regulator installed.
Aug 25, 2014 | 2002 Nissan Altima
Acoustic Solution ICS106i car sound dock won`t save settings when car engine switched off
the are two red positif wires for a radio.1 for turn off whit the ignition key.and one stay powered for excample your settings.
see if bolt conected
Feb 26, 2014 | Cars & Trucks
Wire is supposed to be connected to other wire. Find other wire to connect it to. You don't need a new motor.
Oct 07, 2013 | GMC Cars & Trucks
Pool filter pump won't shut off.
I'm assuming it continues to run when you switch the system to "service" mode. You probably have a relay stuck shut. Unless you are very comfortable with working with high voltage it's best to get a tech out to verify the problem and switch out the relay. If you are okay with it the replacement isn't very difficult. You'll have 4 or 6 wires to move from the old relay to the new one, and switch out the small black and red paired wires that go from the relay to the control board. Make certain that your breaker is off while changing it out.
Apr 12, 2013 | Water Pik Aqualink Rs4 Package - Pool and...
Sears canister vacuum rear wheel won't stay on
1) test the power cord for open, defective, or break use the VOM
2) test the fuse for open, loose wire use the VOM
3( tes the motor, for open, short, or defective, need repair.
4)test the switch, for open, or loose wires, or short.
see how to do it.
God bless you
Jul 10, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
Pto light stays on, tractor won't start (4400)
I would check the PTO switch with a meter, some switches uses 3 or 4 wires 1 or 2 is for the light and the other goes to the clutch. Part of the switch could be bad. Check the voltage on the connector before the switch.
Apr 03, 2012 | Garden
My fiat 2002 fuel cut off switch won't stay down - time for a new one? Or is there a simple fix?
Sorry but the only fix is to replace it, the internal locking pawl is probably worn.
Feb 11, 2012 | 2002 Fiat Punto
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
Our switch doesn't stay in off position
you probabley bent the switch lever so the little indent on the lever won't stay positioned in the off detent. probabley need new switch lever. part doesn't cost much .not hard to put in if your mechanicly inclined , if not a repair center can do it for you.
Sep 12, 2011 | KitchenAid 32685 Mixer
My kenmore dryer will only run if i hold down on the start button. this has happened to me before but i cannot remember the steps to take inorder for it to reset.
first check the door safety switch,, if its bad the dryer won't run,, if that checks out ok, its time for a new switch for the start button, to check these, and do the door switch first, unplug the door safety switch and place a jumper wire between the 2 wires leading to the switch, try starting the machine making sure your away from any moving parts , if this works, replace the switch, if it stays the same, do this same procedure to the switch for the start button
Jun 21, 2011 | Kenmore Dryers
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
19 people viewed this question
Top Westwind Dryers Experts
Dan Webster
Dan Webster
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
