Question about GE Adora Over the Range Microwave. Spacemaker 1.9 cu. ft. in
Arcing and flashing during cooking cycle - GE Adora Over the Range Microwave. Spacemaker 1.9 cu. ft. in
  • 2,113 Answers
Arcing and flashing either has to do with having metal parts inside that are not chromed perfectly (better yet only put metal in if it's a microwave convection oven on convection setting only), or some of the powder coating on the inside of the cabinet is damaged. Or a twist tie etc was inside during use. If the cabinet is damaged dispose of unit.
Posted on Oct 21, 2013
Hi. Our 1 1/2 year old Sharp KB6524PS Microwave Drawer: While cooking oatmeal, at start of cycle, the microwave started arcing, then smoking. Shut off at 15 seconds. Microwave-safe china used.
I expect the arcing came from the waveguide cover or aerial cover having either a crack or carbonised food particles on it.
A new cover may affect a cure if the magnetron is not damaged.
Aug 18, 2017 | Sharp Microwave Ovens
Sharp R959SLMA
Could be arcing around HV transformer or even an HV wire, Sometimes an insulator on a capacitor will get old, dusty or breakdown and arc between the terminals. Have you ran this with the cover off to see if you can see any visual arcing??? If it cooks sure sounds like it is probably not the mag. Something supplying power to the mag arcing to ground I would expect.
Aug 18, 2017 | Sharp R959SLMA 900 Watts Convection /...
My microwave arcs every time I try to heat something. The silver colored plate on the interior right side of the cabinet appears to be burned. What happened and can it be fixed?
This arcing is caused by food splatter when something 'popped' or 'exploded' during an earlier cooking cycle. The food particle remained and every time the microwave gets used, this particle continues to cook until it turns into carbon. This can be as small as the tip of a pin. Carbon reacts very violently to RF energy (which is what causes the food to heat). You need to carefully remove the "waveguide cover". Clean it and check for a burned spot. You also need to inspect the inside of the "waveguide" once the cover is off. Clean it also. Make sure there is no grease or other foreign matter inside there and be sure not to leave anything in there (paper towel piece, etc..). If any of the paint inside the waveguide is burned, and if it can't be sanded off and touched up with catalytic paint, you need a new microwave oven. If the burned area is limited to the waveguide cover and you can't find a replacement, you can buy a sheet of mica material from a parts house and use the old cover as a template to make a new one. Also, "If you are on Gilligan's Island" and can't get any new material, you can cut the burned spot out and cover the hole on both sides of the waveguide cover with cellophane tape. Do this at your own risk but usually it works fine.......
Nov 04, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave is arcing and making a popping noise as if something metal was in there while cooking.
I will assume that you do not have any metal items or bits of tinfoil lying around inside the oven.
If the sparks are happening on the inside of the microwave's cooking area while you are cooking, then make sure you clean the inner surfaces really well. Be sure to remove any cooked on food particles that may have splashed up during cooking.
Most likely you have some corrosion or dried food debris inside the cooking area, or perhaps even some food particles stuck to your WAVEGUIDE COVER PLATE. A dirty waveguide cover plate can certainly cause the arcing and sparking you describe.
If the thorough cleaning does not work, you may need to replace the waveguide cover. Here is a link to a short video that shows you exactly how to replace the wave guide cover yourself:
http://www.youtube.com/watch?v=M0xsXjhefy4
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the video at the website indicated.
If the sparks are coming from somewhere other that the cooking area, then your unit may need more significant electrical repairs or service.
Here is a link to another expert's excellent Microwave Troubleshooting Guide:
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
If you choose to rate Heatman 101's tip using the Thumbs Up scale provided, I thank you very much for your time and consideration.
I hope that was helpful to you, good luck and take care.
Joe.
Jun 21, 2011 | Samsung SMH9187ST Microwave Oven
While cooking in our Whirlpool GH5184 microwave an arcing appeared near the L/H lower corner of the unit. After shutting it off we observed a black arc mark on the inside of the door and a small hole from...
This is caused by either carbon arcing from carbonated food deposits or metal dish or bowl being used inside the machine causing a track. Even a recycled paper towel can cause it as the towels have metal traces in them.
Dec 13, 2010 | Whirlpool GH5184XPQ Microwave Oven
Build in microwave started to sparkling during cook cycle
there is some exposed metal in the cooking chamber, look for scartched paint or exposed screws, paint them or place tape over them.
Aug 18, 2009 | Thermador Microwave Ovens
Randonly arced during cooking. Repositioned food, stopped arcing. Now the microway quite working. broke?
Chek the wave guide burned. or the painting is corroded inside the oven.
May 04, 2009 | Microwave Ovens
Sharp R-510 FK dangerous noise
Hello. To me, it sounds like something is stuck to the inside of your cavity and it is arcing, as you are seeing a bright flash, and hearing it. I would take apart/clean everything inside the cooking area, something is causing a problem in there. Usually just a good cleaning is all it needs, as the debris is making a focus point for the energy. Try putting a small glass of water, only 1/4 full, and watch while you start it, to see where the arcing is, it won't hurt anything for a second or 10.
Hope that helped, and thank you.
Mar 29, 2009 | Sharp R-510HW Microwave Oven
Microwave Magnetron tube has arced
REPLCE THE MAG TUBE AND ***
Feb 08, 2009 | LG Microwave Ovens
GE Adora Over the Range Microwave. Spacemaker 1.9 cu. ft. in Logo
80 people viewed this question
Top GE Adora Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a GE Adora Microwave Oven Expert? Answer questions, earn points and help others
